So this is the error while installing the recent version of EdgeImpulse CLI on Raspbian Buster 10
The previous version is working perfect though, and there is no specific need of the latest version, but reporting the error faced -
npm notice
npm notice New minor version of npm available! 7.5.4 -> 7.6.3
npm notice Changelog: https://github.com/npm/cli/releases/tag/v7.6.3
npm notice Run npm install -g npm@7.6.3 to update!
npm notice
npm ERR! code 127
npm ERR! path /home/pi/.npm-global/lib/node_modules/edge-impulse-cli/node_modules/sharp
npm ERR! command failed
npm ERR! command sh -c (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
npm ERR! info sharp Using cached /home/pi/.npm/_libvips/libvips-8.10.5-linux-armv7.tar.br
npm ERR! prebuild-install WARN install No prebuilt binaries found (target=3 runtime=napi arch=arm libc= platform=linux)
npm ERR! sh: 1: node-gyp: not found
npm ERR! /home/pi/.npm/_logs/2021-03-12T13_18_25_126Z-debug.log
Can you attach the debug log? A couple of basic things to try:
- Make sure nodejs and python are installed
- run npm uninstall and then install again
@dhruvsheth
This is a weird error… Where did you get your Node.js installation from?
I don’t know how I missed the notification. Thanks for your reply. So, I followed and documented a process for installation for Raspbian, here - https://github.com/dhruvsheth-ai/edge-impulse-cli
The installation command was -
$ curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
$ sudo apt-get install -y nodejs
The earlier version of EdgeImpulse CLI released during Himax vision board, for live view of data from the board works just fine. This has some build errors.
No hurry on this, since the previous version is still usable. But wondering what’s the error
I did not change PATH or did not make any changes these days, but today, it installed perfectly to v1.12.5. Really weird.
Log -
$ npm install -g edge-impulse-cli
removed 1 package, changed 27 packages, and audited 313 packages in 2m
18 packages are looking for funding
run `npm fund` for details
2 low severity vulnerabilities
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
Thanks for your help @yodaimpulse @janjongboom
@dhruvsheth Thanks again, we’re going to be releasing a version of the CLI that does not depend on sharp for v1.13 - we’ve seen some other issues on Apple M1 too.
