Hi!
I was installing Edge Impulse CLI on my Windows device and it didn’t cause any errors. While I was trying to do the same on my Ubuntu machine I got this -
npm WARN checkPermissions Missing write access to /usr/local/lib
npm ERR! code EACCES
npm ERR! syscall access
npm ERR! path /usr/local/lib
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, access ‘/usr/local/lib’
npm ERR! { [Error: EACCES: permission denied, access ‘/usr/local/lib’]
npm ERR! stack:
npm ERR! ‘Error: EACCES: permission denied, access ‘/usr/local/lib’’,
npm ERR! errno: -13,
npm ERR! code: ‘EACCES’,
npm ERR! syscall: ‘access’,
npm ERR! path: ‘/usr/local/lib’ }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR! /home/arijit/.npm/_logs/2020-12-17T10_19_50_892Z-debug.log
Note that this is a first time installation process and I have NodeJs version 10.19.0 .
I tried uninstalling and reinstallation but it didn’t work. Can anyone help me solve this issue ?
