I am trying to implement a ResNet based NN architecture in Edge Impulse NN classifier. In the “Keras expert mode” I am using the Keras functional API to declare my network.
But during the “Calculating performance metrics…” stage I am getting the following error.
Job started
Splitting data into training and validation sets OKTraining model…
Training on 2693 inputs, validating on 674 inputs
Epoch 47% done
85/85 - 20s - loss: 0.7918 - accuracy: 0.5978 - val_loss: 0.5008 - val_accuracy: 0.7522
Finished trainingSaving best performing model…
Still saving model…
Converting TensorFlow Lite float32 model…
Converting TensorFlow Lite int8 quantized model with float32 input and output…
Converting TensorFlow Lite int8 quantized model with int8 input and output…
File “/home/train.py”, line 734, in
main_function()
File “/home/train.py”, line 723, in main_function
file_int8=os.path.join(dir_path, ‘model_quantized_int8_io.tflite’))
File “/home/train.py”, line 381, in get_model_metadata
‘layers’: describe_layers(keras_model),
File “/home/train.py”, line 356, in describe_layers
‘shape’: layer.input.shape[1],
AttributeError: ‘list’ object has no attribute ‘shape’Application exited with code 1 (Error)
Job failed (see above)
I assume this is generated from the input to Add() layer, which takes a list as input.
Has anyone implemented ResNet models on Edge Impulse? Any information regarding this would be greatly helpful.
Thank you for your time
I am including my NN code below.
import tensorflow as tf
from tensorflow import keras
from tensorflow.keras import layers
from tensorflow.keras.optimizers import Adammodel architecture
channels = 1
columns = 40
rows = int(input_length / (columns * channels))Define graph
inputs = keras.Input(shape=(input_length,))
Reshape to H*W format
x = layers.Reshape((rows, columns, channels), input_shape=(input_length, ))(inputs)
Layer Conv0
x = layers.Conv2D(19, kernel_size=3, activation=‘relu’, kernel_constraint=tf.keras.constraints.MaxNorm(1), padding=‘same’,use_bias=False)(x)
Average pool layer
x = layers.AveragePooling2D(pool_size=(4,3), strides=(4,3), padding=‘same’)(x)
Residual block 1
y = x
x = layers.Add(input_shape=x.shape)([x,y])Fully connected layer
x = layers.Flatten()(x)
outputs = layers.Dense(classes, activation=‘softmax’, use_bias=True, name=‘y_pred’)(x)model = keras.Model(inputs=inputs, outputs=outputs, name=“resmodel”)
this controls the learning rate
opt = Adam(lr=0.005, beta_1=0.9, beta_2=0.999)
this controls the batch size, or you can manipulate the tf.data.Dataset objects yourself
BATCH_SIZE = 32
train_dataset, validation_dataset = set_batch_size(BATCH_SIZE, train_dataset, validation_dataset)
callbacks.append(BatchLoggerCallback(BATCH_SIZE, train_sample_count))train the neural network
model.compile(loss=‘categorical_crossentropy’, optimizer=opt, metrics=[‘accuracy’])
model.fit(train_dataset, epochs=1, validation_data=validation_dataset, verbose=2, callbacks=callbacks)
