Getting this error after running the setup script and trying to connect to Edge Impulse
ugiri@ugiri-desktop:~$ edge-impulse-linux
internal/modules/cjs/loader.js:990
throw err;
SyntaxError: /usr/local/lib/node_modules/edge-impulse-linux/node_modules/ajv/lib/refs/json-schema-draft-07.json: Unexpected end of JSON input
at JSON.parse ()
at Object.Module._extensions…json (internal/modules/cjs/loader.js:987:27)
at Module.load (internal/modules/cjs/loader.js:812:32)
at Function.Module._load (internal/modules/cjs/loader.js:724:14)
at Module.require (internal/modules/cjs/loader.js:849:19)
at require (internal/modules/cjs/helpers.js:74:18)
at Object. (/usr/local/lib/node_modules/edge-impulse-linux/node_modules/ajv/lib/definition_schema.js:3:18)
at Module._compile (internal/modules/cjs/loader.js:956:30)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:973:10)
