Error when i tried to compile a arduino code for object detection
I need some help. I’m trying to make a project to detect object using a esp32-cam and arduino ide. I’ve used edge impulse to make the object detection possible. Then when i got the example code, I tried to commpile it and got an error. What did I do wrong?
the error:
exit status 1
‘CAMERA_FB_IN_PSRAM’ was not declared in this scope
Hi @Oddie711,
Please post the exact error you are seeing, any relevant code snippets (or a link to the code you are using), and your project ID so that we can best help troubleshoot your error.
Project ID : 397430
Full Error :
Arduino: 1.8.19 (Windows 10), Board: “AI Thinker ESP32-CAM”
In file included from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/common.h:29:0,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/reference/integer_ops/pooling.h:21,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/micro/kernels/pooling.h:23,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/micro/micro_mutable_op_resolver.h:33,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/micro/all_ops_resolver.h:19,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/classifier/inferencing_engines/tflite_helper.h:35,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/classifier/inferencing_engines/tflite_eon.h:28,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:44,
             from C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/Object_Detection_TA_inferencing.h:49,
             from C:\Users\Asus\AppData\Local\Temp\arduino_modified_sketch_31264\esp32_camera.ino:27:
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h: In function ‘T tflite::TfLiteRound(T)’:
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:26:35: error: ‘round’ is not a member of ‘std’
#define TF_LITE_GLOBAL_STD_PREFIX std
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:32:12: note: in expansion of macro ‘TF_LITE_GLOBAL_STD_PREFIX’
 return TF_LITE_GLOBAL_STD_PREFIX::std_name(x);    \
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:35:1: note: in expansion of macro ‘DECLARE_STD_GLOBAL_SWITCH1’
DECLARE_STD_GLOBAL_SWITCH1(TfLiteRound, round);
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:26:35: note: suggested alternative:
In file included from C:\Users\Asus\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/esp32-hal.h:34:0,
             from C:\Users\Asus\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32/Arduino.h:35,
             from sketch\esp32_camera.ino.cpp:1:
C:\Users\Asus\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/newlib/math.h:278:15: note: ‘round’
extern double round _PARAMS((double));
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h: In function ‘T tflite::TfLiteExpm1(T)’:
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:26:35: error: ‘expm1’ is not a member of ‘std’
C:\Users\Asus\OneDrive\Dokumen\Arduino\libraries\Object_Detection_TA_inferencing\src/edge-impulse-sdk/tensorflow/lite/kernels/internal/cppmath.h:36:1: note: in expansion of macro ‘DECLARE_STD_GLOBAL_SWITCH1’
DECLARE_STD_GLOBAL_SWITCH1(TfLiteExpm1, expm1);
C:\Users\Asus\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/newlib/math.h:290:15: note: ‘expm1’
extern double expm1 _PARAMS((double));
C:\Users\Asus\AppData\Local\Temp\arduino_modified_sketch_31264\esp32_camera.ino: At global scope:
esp32_camera:119:20: error: ‘CAMERA_FB_IN_PSRAM’ was not declared in this scope
esp32_camera:120:18: error: ‘CAMERA_GRAB_WHEN_EMPTY’ was not declared in this scope
esp32_camera:121:1: error: ‘camera_config_t’ has no non-static data member named ‘fb_location’
exit status 1
This report would have more information with
“Show verbose output during compilation”
option enabled in File → Preferences.
Hi @Oddie711,
I cannot replicate the error. Could you try Arduino 2.x and see if it works for you? I got it to compile on Arduino 2.2.1 with the AI Thinker ESP32-CAM board selected.
