While coding my Arduino 33 BLE Sense I get this error message
No device found on cu.Bluetooth-Incoming-Port
Failed uploading: uploading error: exit status 1
Please provide a solution
I’ll assume you deployed the firmware from the Deployment page:
flash_windows.bat
I’ll assume you then ran from a Windows command prompt: edge-impulse-daemon
Bluetooth COM Port
You should be selecting the COM port instantiated when the Nano was plugged into your computer not the Bluetooth port.
Look in Device Manager under Ports (COM & LPT) to see what COM port your Nano is connected to.
