I am getting the following error when trying to compile the edge impulse linux standalone camera example using c++ and hardware acceleration flags "
APP_CAMERA=1 TARGET_LINUX_AARCH64=1 USE_FULL_TFLITE=1 CC=clang CXX=clang++ make -j3". EON is OFF and using float32 model:
/usr/bin/ld: tflite-model/tflite_learn_5_compiled.o: in function (anonymous namespace)::EonMicroContext::~EonMicroContext()': /home/tstacey00/example-standalone-inferencing-linux/tflite-model/tflite_learn_5_compiled.cpp:1232: undefined reference to tflite::MicroContext::~MicroContext()β
/usr/bin/ld: tflite-model/tflite_learn_5_compiled.o: in function tflite_learn_5_init(void* (*)(unsigned long, unsigned long))': /home/tstacey00/example-standalone-inferencing-linux/tflite-model/tflite_learn_5_compiled.cpp:1234: undefined reference to tflite::MicroContext::MicroContext(tflite::MicroAllocator*, tflite::Model const*, tflite::MicroGraph*)β
/usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/tflite-model/tflite_learn_5_compiled.cpp:1299: undefined reference to tflite::Register_CONV_2D()' /usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/tflite-model/tflite_learn_5_compiled.cpp:1300: undefined reference to tflite::Register_DEPTHWISE_CONV_2D()β
/usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/tflite-model/tflite_learn_5_compiled.cpp:1301: undefined reference to tflite::Register_PAD()' /usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/tflite-model/tflite_learn_5_compiled.cpp:1302: undefined reference to tflite::Register_ADD()β
/usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/tflite-model/tflite_learn_5_compiled.cpp:1303: undefined reference to tflite::Register_SOFTMAX()' /usr/bin/ld: tflite-model/tflite_learn_5_compiled.o:(.data.rel.ro+0x40): undefined reference to tflite::MicroContext::AllocateTempInputTensor(TfLiteNode const*, int)β
/usr/bin/ld: tflite-model/tflite_learn_5_compiled.o:(.data.rel.ro+0x48): undefined reference to tflite::MicroContext::AllocateTempOutputTensor(TfLiteNode const*, int)' /usr/bin/ld: tflite-model/tflite_learn_5_compiled.o:(.data.rel.ro+0x50): undefined reference to tflite::MicroContext::AllocateTempIntermediateTensor(TfLiteNode const*, int)β
/usr/bin/ld: tflite-model/tflite_learn_5_compiled.o:(.data.rel.ro+0x78): undefined reference to typeinfo for tflite::MicroContext' /usr/bin/ld: source/camera.o: in function inference_tflite_setup(ei_learning_block_config_tflite_graph_t*, unsigned long*, TfLiteTensor**, TfLiteTensor**, TfLiteTensor**, TfLiteTensor**, tflite::MicroInterpreter**, std::unique_ptr<void, void ()(void)>&) [clone .constprop.0]β:
/home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:120: undefined reference to tflite::AllOpsResolver::AllOpsResolver()' /usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:125: undefined reference to tflite::MicroInterpreter::MicroInterpreter(tflite::Model const*, tflite::MicroOpResolver const&, unsigned char*, unsigned long, tflite::MicroResourceVariables*, tflite::MicroProfilerInterface*)β
/usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:130: undefined reference to tflite::MicroInterpreter::AllocateTensors(bool)' /usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:137: undefined reference to tflite::MicroInterpreter::input(unsigned long)β
/usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:138: undefined reference to tflite::MicroInterpreter::output(unsigned long)' /usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:141: undefined reference to tflite::MicroInterpreter::output(unsigned long)β
/usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:142: undefined reference to tflite::MicroInterpreter::output(unsigned long)' /usr/bin/ld: source/camera.o: in function run_nn_inference_from_dsp(ei_learning_block_config_tflite_graph_t*, ei::ei_signal_t*, ei::ei_matrix*)β:
/home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:251: undefined reference to tflite::MicroInterpreter::Invoke()' /usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:262: undefined reference to tflite::MicroInterpreter::~MicroInterpreter()β
/usr/bin/ld: source/camera.o: in function run_nn_inference(ei_impulse const*, ei::ei_matrix*, ei_impulse_result_t*, void*, bool)': /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:177: undefined reference to tflite::MicroInterpreter::Invoke()β
/usr/bin/ld: source/camera.o: in function inference_tflite_run': /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:179: undefined reference to tflite::MicroInterpreter::~MicroInterpreter()β
/usr/bin/ld: /home/tstacey00/example-standalone-inferencing-linux/./edge-impulse-sdk/classifier/inferencing_engines/tflite_micro.h:197: undefined reference to `tflite::MicroInterpreter::~MicroInterpreter()β
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make: *** [Makefile:187: runner] Error 1
Any ideas would be appreciated.
