I’m new to this and I hope someone can help, Please
I got an error when I am trying to train FOMO model to recognize digits on screen. I start the training and I get the following error:
Creating job… OK (ID: 5780344)
Scheduling job in cluster…
Job started
Job started
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/data/util/structure.py”, line 106, in normalize_element
spec = type_spec_from_value(t, use_fallback=False)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/data/util/structure.py”, line 489, in type_spec_from_value
raise TypeError(“Could not build a TypeSpec for {} with type {}”.format(
TypeError: Could not build a TypeSpec for [{‘sampleId’: 172885713, ‘boundingBoxes’: [{‘label’: 8, ‘x’: 34, ‘y’: 26, ‘w’: 3, ‘h’: 4}, {‘label’: 7, ‘x’: 31, ‘y’: 26, ‘w’: 2, ‘h’: 4}, {‘label’: 9, ‘x’: 32, ‘y’: 18, ‘w’: 4, ‘h’: 6}, {‘label’: 8, ‘x’: 27, ‘y’: 18, ‘w’: 4, ‘h’: 6}, {‘label’: 3, ‘x’: 32, ‘y’: 10, ‘w’: 3, ‘h’: 6}, {‘label’: 3, ‘x’: 27, ‘y’: 10, ‘w’: 4, ‘h’: 6}, {‘label’: 2, ‘x’: 26, ‘y’: 10, ‘w’: 1, ‘h’: 6}]},
a long long block…
, {‘sampleId’: 172885675, ‘boundingBoxes’: [{‘label’: 5, ‘x’: 35, ‘y’: 29, ‘w’: 2, ‘h’: 4}, {‘label’: 7, ‘x’: 32, ‘y’: 29, ‘w’: 2, ‘h’: 4}, {‘label’: 7, ‘x’: 33, ‘y’: 21, ‘w’: 4, ‘h’: 6}, {‘label’: 7, ‘x’: 29, ‘y’: 21, ‘w’: 3, ‘h’: 6}, {‘label’: 1, ‘x’: 33, ‘y’: 13, ‘w’: 4, ‘h’: 6}, {‘label’: 2, ‘x’: 31, ‘y’: 14, ‘w’: 1, ‘h’: 5}, {‘label’: 2, ‘x’: 27, ‘y’: 14, ‘w’: 1, ‘h’: 5}]}] with type list
File “/home/train.py”, line 321, in
main_function()
File “/home/train.py”, line 242, in main_function
train_dataset, validation_dataset, samples_dataset, X_train, X_test, Y_train, Y_test, has_samples, X_samples, Y_samples = ei_tensorflow.training.get_dataset_from_folder(
File “/app/./resources/libraries/ei_tensorflow/training.py”, line 190, in get_dataset_from_folder
train_dataset, validation_dataset, samples_dataset = get_datasets(X_train, Y_train, X_test, Y_test,
File “/app/./resources/libraries/ei_tensorflow/training.py”, line 347, in get_datasets
train_dataset = get_dataset_standard(X_train, Y_train)
File “/app/./resources/libraries/ei_tensorflow/training.py”, line 212, in get_dataset_standard
return tf.data.Dataset.from_tensor_slices((X_values, Y_values))
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/data/ops/dataset_ops.py”, line 781, in from_tensor_slices
return TensorSliceDataset(tensors, name=name)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/data/ops/dataset_ops.py”, line 4661, in init
element = structure.normalize_element(element)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/data/util/structure.py”, line 111, in normalize_element
ops.convert_to_tensor(t, name=“component_%d” % i))
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/profiler/trace.py”, line 163, in wrapped
return func(*args, **kwargs)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/ops.py”, line 1621, in convert_to_tensor
ret = conversion_func(value, dtype=dtype, name=name, as_ref=as_ref)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/constant_op.py”, line 347, in _constant_tensor_conversion_function
return constant(v, dtype=dtype, name=name)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/constant_op.py”, line 271, in constant
return _constant_impl(value, dtype, shape, name, verify_shape=False,
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/constant_op.py”, line 283, in _constant_impl
return _constant_eager_impl(ctx, value, dtype, shape, verify_shape)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/constant_op.py”, line 308, in _constant_eager_impl
t = convert_to_eager_tensor(value, ctx, dtype)
File “/app/keras/.venv/lib/python3.8/site-packages/tensorflow/python/framework/constant_op.py”, line 106, in convert_to_eager_tensor
return ops.EagerTensor(value, ctx.device_name, dtype)
ValueError: Attempt to convert a value ({‘sampleId’: 172885713, ‘boundingBoxes’: [{‘label’: 8, ‘x’: 34, ‘y’: 26, ‘w’: 3, ‘h’: 4}, {‘label’: 7, ‘x’: 31, ‘y’: 26, ‘w’: 2, ‘h’: 4}, {‘label’: 9, ‘x’: 32, ‘y’: 18, ‘w’: 4, ‘h’: 6}, {‘label’: 8, ‘x’: 27, ‘y’: 18, ‘w’: 4, ‘h’: 6}, {‘label’: 3, ‘x’: 32, ‘y’: 10, ‘w’: 3, ‘h’: 6}, {‘label’: 3, ‘x’: 27, ‘y’: 10, ‘w’: 4, ‘h’: 6}, {‘label’: 2, ‘x’: 26, ‘y’: 10, ‘w’: 1, ‘h’: 6}]}) with an unsupported type (<class ‘dict’>) to a Tensor.
Thanks.
papaaui
