**Question/Issue // How to connect camera OV7675 to my project Project ID: // 318426
Hello everyone, I am working on a project to object detection by using tinyML kit (arduino nano33 BLE) .When I completed the steps and started running the example I get this error:
Sorry for what you are experiencing.
Have you installed the correct library for the Camera OV7675?
From your terminal, I can suggest the following,
Make sure you have changed the mode from flash mode but pressing a reset button once.
Change the deployment option instead of using a Library, try to deploy using a Flash file related to the operating system you are using.
@Ipyana Thank you very much for your interest. I downloaded the OV767X Library because I did not find a library specifically for the OV7675 camera. I will give you feedback
@eng771.ruqaya.alaa If you are using Arduino IDE, include that Library you have downloaded then go to File->Examples->Arduino_767X->ConnectionTest. Compile the code, then upload it to your Arduino Nano 33 BLE Sense, and check if the camera is detected.
@eng771.ruqaya.alaa If you have installed it successful on your Arduino IDE, go to File->Examples->Arduino_767X then choose ConnectionTest. This works for both installations using either Library Manager or add library as zip file. So, if you are using Arduino IDE, please check the example using the path I have provided.
@eng771.ruqaya.alaa I understand that each library has its own set of examples, which are displayed in separate windows. To access them, click the down arrow next to “Examples for Arduino Nano” and select the desired sensor from the list. Next, choose Arduino OV767X and then select ConnectionTest.
If you don’t mind, we can have a Google Meet or use AnyDesk remote desktop to find a solution. Please let me know which option works better for you.
@Ipyana
WARNING: library Arduino_OV767X-0.0.2 claims to run on mbed architecture(s) and may be incompatible with your current board which runs on mbed_nano architecture(s).
Sketch uses 96176 bytes (9%) of program storage space. Maximum is 983040 bytes.
Global variables use 96912 bytes (36%) of dynamic memory, leaving 165232 bytes for local variables. Maximum is 262144 bytes.
Device : nRF52840-QIAA
Version : Arduino Bootloader (SAM-BA extended) 2.0 [Arduino:IKXYZ]
Address : 0x0
Pages : 256
Page Size : 4096 bytes
Total Size : 1024KB
Planes : 1
Lock Regions : 0
Locked : none
Security : false
Erase flash
Done in 0.000 seconds
Write 96184 bytes to flash (24 pages)
[==============================] 100% (24/24 pages)
Done in 4.009 seconds
To resolve any issues related to Mbed Architecture on your Arduino IDE, you can try uninstalling all boards from the board’s manager associated with it and then install the latest version from the Boards Manager. Make sure that you select Mbed OS by Arduino. As an example, I have installed two boards - Mbed OS Edge Boards and Arduino Mbed OS Nano Boards.
