I am trying to use the Edge-Impulse CLI, and I have installed it with npm install -g edge-impulse-cli --force
However, this is the error when I try to run it edge-impulse-daemon
/usr/local/lib/node_modules/edge-impulse-cli/node_modules/bindings/bindings.js:121
throw e;
Error: The module '/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 83. This version of Node.js requires
NODE_MODULE_VERSION 93. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
at Object.Module._extensions..node (node:internal/modules/cjs/loader:1187:18)
at Module.load (node:internal/modules/cjs/loader:981:32)
at Function.Module._load (node:internal/modules/cjs/loader:822:12)
at Module.require (node:internal/modules/cjs/loader:1005:19)
at require (node:internal/modules/cjs/helpers:102:18)
at bindings (/usr/local/lib/node_modules/edge-impulse-cli/node_modules/bindings/bindings.js:112:48)
at Object.<anonymous> (/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/lib/darwin.js:2:36)
at Module._compile (node:internal/modules/cjs/loader:1103:14)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
at Module.load (node:internal/modules/cjs/loader:981:32) {
code: 'ERR_DLOPEN_FAILED'
I even rebuilt the packages. It still gives me the error
