I have built an impulse model and wanted to test it locally in my ThunderBoard-2 board using Simplicity Studio.
I have followed the steps detailed here:
After doing the steps, I try to build the project but I got this error:
It all seems to be a problem finding some files. Here the prompt:
|fatal error: edge-impulse-sdk/tensorflow/lite/c/builtin_op_data.h: No such file or directory|trained_model_compiled.cpp|/example-standalone-inferencing-silabs-tb-sense-2/edgeimpulse/tflite-model|line 26|C/C++ Problem|
|fatal error: edge-impulse-sdk/tensorflow/lite/micro/debug_log.h: No such file or directory|ei_classifier_porting.h|/example-standalone-inferencing-silabs-tb-sense-2/edgeimpulse/edge-impulse-sdk/porting|line 28|C/C++ Problem|
This looks like it can be that the project was not properly generated/imported or edge-impulse-sdk is missing. I think the former.
It’s important that step 11 (close and re-open the studio) is followed. Otherwise when you click ‘Force Generation’ the .slcp file would get modified resulting in incorrect project properties.
Can you try following the guide and monitoring the .slcp before and after ‘Force generation’ and see to it that it doesn’t change (due to ‘Force Generation’).
I noticed ei-workspace/ in your project. This folder shouldn’t be enumerated in the project.
Can you try what you did but then (Step 10) copying the contents in ei-workspace instead of from the root of the repo. Let me know if that helps.
It looked like you copied all the files and directory from example-standalone-inferencing-silabs-tb-sense-2/ rather from example-standalone-inferencing-silabs-tb-sense-2/ei-workspace.
Try removing everything and import the project again starting from Step 1 again.
And in Step 10 you first navigate to example-standalone-inferencing-silabs-tb-sense-2/ei-workspace and drag,copy the contents of this directory to Simplicity Studio.
I havent copied the whole folder. As I mentioned in the previous message, I added only the files inside the folder to the project explorer (see the first image attached in the previous message) . The thing is that when I push “save” in the “Project Generators” window, everything changes by itself, automatically. It creates a folder called: ei-workspace , and moves the app.c, .h, ei_main.cpp, .h, main.c inside that folder. I dont know why. It is not something I have done, it does it by itself when I save the “Project Generators”.
Is it to do something with the SDK version? I see in your Figure you have the gecko_sdk_3.2.1, but in my case that folder is shadowed and a newer version is shown: gecko_sdk_3.2.3.
Thank you
between steps 9-12 you’ll see in the lower right corner of Simplicity Studio the message C/C++ Indexer. Wait for the process to complete before advancing to the next step.
After editing the project generators (Step 12). You’ll get Generate Configurable Project followed by C/C++ Indexer. Wait for both of these processes to end before Force Generation (Step 13).
You should notice that Simplicity Studio would have created gecko_sdk_3.1.1 (or gecko_sdk_3.2.3 if using the latest SDK) while gecko_sdk_3.2.1 is present. Either way, building the project is successful. See images below:
hi @rjames
I tried following the steps you said, and waiting for the indexer to update in every step, but it keeps doing the same than before.
Do you think is likely to have a meeting ( I know we are on holidays, so it could be whenever you are able) for you to guide me in live. I think is gonna be quicker in this way.
Hey @rjames
I have tried all the steps in a Windows 10 machine.
It keeps without working, and doing the same (generating the ei-workspace folder). But now an error prompts. Hope it helps.
Failed to generate example-standalone-inferencing-silabs-tb-sense-2-main for Example-standalone-inferencing-silabs-tb-sense-2-main [example-standalone-inferencing-silabs-tb-sense-2-main]
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\platform\service’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\app\common\util\app_assert’.
Resource ‘/example-standalone-inferencing-silabs-tb-sense-2-main/gecko_sdk_3.2.3/app/common/util/app_assert’ does not exist.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\aesni.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\arc4.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\aria.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\bn_mul.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\certs.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\chacha20.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\check_config.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\cipher.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\cmac.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\compat-1.3.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\debug.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\des.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\dhm.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\ecdsa.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\ecp.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\entropy.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\md_internal.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\memory_buffer_alloc.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\net.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\nist_kw.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\pkcs12.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\pkcs5.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\rsa_internal.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\sha1.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\ssl.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\ssl_cookie.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\ssl_internal.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\mbedtls\include\mbedtls\threading.h’.
Resource already exists on disk: ‘/example-standalone-inferencing-silabs-tb-sense-2-main/gecko_sdk_3.2.3/util/third_party/crypto/mbedtls/include/psa’.
Resource ‘/example-standalone-inferencing-silabs-tb-sense-2-main/gecko_sdk_3.2.3/util/third_party/crypto/mbedtls/include/psa’ does not exist.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\sl_component\sl_mbedtls_support\inc\sha256_alt.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\sl_component\sl_mbedtls_support\inc\sha512_alt.h’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\sl_component\sl_psa_driver\src\crypto_management.c’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\sl_component\sl_psa_driver\src\sli_crypto_transparent_driver_cipher.c’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\sl_component\sl_psa_driver\src\sli_crypto_transparent_driver_mac.c’.
A resource already exists on disk ‘C:\Users\MASTER\SimplicityStudio\v5_workspace\example-standalone-inferencing-silabs-tb-sense-2-main\gecko_sdk_3.2.3\util\third_party\crypto\sl_component\sl_psa_driver\inc’.
Resource ‘/example-standalone-inferencing-silabs-tb-sense-2-main/gecko_sdk_3.2.3/util/third_party/crypto/sl_component/sl_psa_driver/inc’ does not exist.
Problems encountered while deleting resources.
One question, in order to use the impulse over my own Simplicty Studio project, do I only need the files downloaded from the Edge Impulse web?.. I mean, just add these downloaded folders to my existing project and do the calls to the impulse function with the raw data filled?
