I am using nano_ble33_sense_accelerometer_continuos example to modify and upload to wio terminal, but I am getting errors on the following keywords “rtos”, “inference_thread”, “mbed”, “osPriorityLow”. Can someone help me which libraries I need to import or include any files?
Thanks!
Hello @f20190094,
Can you please copy/paste the full error output and describe how you are compiling?
This is my code
#include <testing_inferencing.h>
// #include <Arduino_LSM9DS1.h>
#include"LIS3DHTR.h" //include accelerometer library
LIS3DHTR<TwoWire> lis; //Initialize accelerometer
static uint32_t run_inference_every_ms = 200;
static rtos::Thread inference_thread(osPriorityLow);
static float buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = { 0 };
static float inference_buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
/* Forward declaration */
void run_inference_background();
void setup()
Serial.begin(115200);
lis.begin(Wire1); //Start accelerometer
/*if (!IMU.begin()) {
ei_printf("Failed to initialize IMU!\r\n");
else {
ei_printf("IMU initialized\r\n");
lis.setOutputDataRate(LIS3DHTR_DATARATE_200HZ); //Data output rate (5Hz up to 5kHz)
lis.setFullScaleRange(LIS3DHTR_RANGE_8G);
return;
inference_thread.start(mbed::callback(&run_inference_background));
* @brief Printf function uses vsnprintf and output using Arduino Serial
* @param[in] format Variable argument list
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
* @brief Run inferencing in the background.
// wait until we have a full buffer
delay((EI_CLASSIFIER_INTERVAL_MS * EI_CLASSIFIER_RAW_SAMPLE_COUNT) + 100);
// This is a structure that smoothens the output result
// With the default settings 70% of readings should be the same before classifying.
ei_classifier_smooth_t smooth;
ei_classifier_smooth_init(&smooth, 10 /* no. of readings */, 7 /* min. readings the same */, 0.8 /* min. confidence */, 0.3 /* max anomaly */);
while (1) {
// copy the buffer
memcpy(inference_buffer, buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE * sizeof(float));
signal_t signal;
int err = numpy::signal_from_buffer(inference_buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
if (err != 0) {
return;
// Run the classifier
if (err != EI_IMPULSE_OK) {
return;
// print the predictions
ei_printf("Predictions ");
ei_printf(": ");
// ei_classifier_smooth_update yields the predicted label
const char *prediction = ei_classifier_smooth_update(&smooth, &result);
ei_printf("%s ", prediction);
// print the cumulative results
ei_printf(" [ ");
for (size_t ix = 0; ix < smooth.count_size; ix++) {
ei_printf("%u", smooth.count[ix]);
if (ix != smooth.count_size + 1) {
ei_printf(", ");
else {
ei_printf(" ");
ei_printf("]\n");
delay(run_inference_every_ms);
ei_classifier_smooth_free(&smooth);
* @brief Get data and run inferencing
* @param[in] debug Get debug info if true
void loop()
while (1) {
// roll the buffer -3 points so we can overwrite the last one
numpy::roll(buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, -3);
// read to the end of the buffer
/*IMU.readAcceleration(
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2],
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1]
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3] = lis.getAccelerationX();
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2] = lis.getAccelerationY();
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] = lis.getAccelerationZ();
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 3] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 2] *= CONVERT_G_TO_MS2;
buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] *= CONVERT_G_TO_MS2;
// and wait for next tick
uint64_t time_to_wait = next_tick - micros();
delay((int)floor((float)time_to_wait / 1000.0f));
delayMicroseconds(time_to_wait % 1000);
#endif
And this is the error
C:\Users\Aryan\AppData\Local\Temp\.arduinoIDE-unsaved2022124-17740-kuu5up.c9qh\static_buffer\static_buffer.ino:35:8: error: 'rtos' does not name a type; did you mean 'ltoa'?
ltoa
C:\Users\Aryan\AppData\Local\Temp\.arduinoIDE-unsaved2022124-17740-kuu5up.c9qh\static_buffer\static_buffer.ino: In function 'void setup()':
C:\Users\Aryan\AppData\Local\Temp\.arduinoIDE-unsaved2022124-17740-kuu5up.c9qh\static_buffer\static_buffer.ino:66:5: error: 'inference_thread' was not declared in this scope
C:\Users\Aryan\AppData\Local\Temp\.arduinoIDE-unsaved2022124-17740-kuu5up.c9qh\static_buffer\static_buffer.ino:66:5: note: suggested alternative: 'inference_buffer'
inference_buffer
C:\Users\Aryan\AppData\Local\Temp\.arduinoIDE-unsaved2022124-17740-kuu5up.c9qh\static_buffer\static_buffer.ino:66:28: error: 'mbed' has not been declared
Multiple libraries were found for "Adafruit_ZeroDMA.h"
Used: C:\Users\Aryan\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.2\libraries\Adafruit_ZeroDMA
Not used: C:\Users\Aryan\Documents\Arduino\libraries\Adafruit_Zero_DMA_Library
Compilation error: exit status 1}
I copy pasted my code in static_buffer file in examples -> testing_inferencing. And compiled the same.
Hi there!
So, Wio Terminal does not use mbedOS, relying instead on FreeRTOS. You can have a look at working example of continuous inference with explanation for Wio Terminal here:
Cheers, hope that helped!
I used the method which you mentioned. But it doesn’t display the predictions on the serial monitor, and I have noticed that serial monitor only prints things that are inside loop(). is there a way around it? pardon me as I am new to IoT technology.
So, I’ve noticed that links to Github repository for that project were cahnged, here is the right link (I also updated the article):
WioTerminal_EI_People_Counting_Continious.ino prints out results on Serial monitor and controls LCD screen backlit, based on the results of inference.
I compared my code with the code given in your link. I didn’t find any fault in my code. But it is showing this error
ERR: Failed to run classifier (-6)
Fatal Error
I also ran the this code which worked fine and this is also continuos and similar to my code. can you please please look at my code. I don’t even know what’s wrong.
#include <Fall_detection_3spec_inferencing.h>
#include <Seeed_Arduino_FreeRTOS.h>
#define ERROR_LED_LIGHTUP_STATE HIGH
static float buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE] = {0};
uint8_t axis_num = 1;
TaskHandle_t Handle_aTask;
TaskHandle_t Handle_bTask;
void setup()
ei_printf("ERR: EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME should be equal to (%d) (the (%d) sensor axes)\n", axis_num, axis_num);
return;
vSetErrorLed(LED_BUILTIN, ERROR_LED_LIGHTUP_STATE);
// Create the threads that will be managed by the rtos
// Sets the stack size and priority of each task
// Also initializes a handler pointer to each task, which are important to communicate with and retrieve info from tasks
xTaskCreate(run_inference_background,"Inference", 512, NULL, tskIDLE_PRIORITY + 2, &Handle_aTask);
xTaskCreate(read_data, "Data collection", 256, NULL, tskIDLE_PRIORITY + 1, &Handle_bTask);
// Start the RTOS, this function will never return and will schedule the tasks.
vTaskStartScheduler();
va_list args;
va_end(args);
if (r > 0) {
static void run_inference_background(void* pvParameters)
while (1) {
// copy the buffer
signal_t signal;
if (err != 0) {
return;
return;
ei_printf(": ");
ei_printf(" [ ");
ei_printf(", ");
else {
ei_printf(" ");
ei_printf("]\n");
static void read_data(void* pvParameters)
while (1) {
numpy::roll(buffer, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, -axis_num);
//buffer[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE - 1] = analogRead(WIO_LIGHT);
void loop()
//nothing, all the work is done in two threads
This is the project link
Hi there!
It seems that
just means that there is not enough RAM for the model. Are you using EON compiled model? What is the architecture?
Another little thing, that I’d recommend would be using
lis.getAcceleration(&buffer[ix], &buffer[ix + 1], &buffer[ix + 2]);
function to get the data from accelerometer in one step. You’ll need to adapt the above line to names of your variables of course.
