@janjongboom
In the Project 3600, I had uploaded data sampled at 104Hz and detected as 108Hz by the uploader.
Today when I ran the uploader, it is detecting as 110Hz. When I am run re-train with a single data, I am getting the following error
Creating job... OK (ID: 196551)
Retraining Spectral features...
Creating windows from 32 files...
[ 1/32] Creating windows from files...
WARN: failed to process Test_M_104: Shape of data does not match earlier data. Expected 1135 columns, but got 1153. Does all your data have the same frequency?
The model does get generated.
When I add more datasets, I am getting the following error
Creating job... OK (ID: 196563)
Creating windows from 38 files...
[ 1/38] Creating windows from files...
WARN: failed to process O.1avi65ss: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65ta: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65tk: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65u0: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65t5: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65t4: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65t0: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65tc: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65tb: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65ps: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65pl: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65j5: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65jk: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65jf: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65ji: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65jv: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65ju: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65jp: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65kk: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process O.1avi65jo: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65jj: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65if: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65j9: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65im: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65jg: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65in: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65is: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65iv: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65ig: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65j2: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
WARN: failed to process M.1avi65hi: Shape of data does not match earlier data. Expected 1153 columns, but got 1135. Does all your data have the same frequency?
[38/38] Creating windows from files...
Created 56 windows: M: 40, O: 16
Scheduling job in cluster...
Job started
Creating features
[ 1/56] Creating features...
[56/56] Creating features...
Created features
Retraining Spectral features OK
Retraining NN Classifier...
Copying features from processing blocks...
Job started
Splitting data into training and validation sets...
Training model
Training on 44 inputs, validating on 12 inputs
Epoch 1/100
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/data_adapter.py", line 1136, in catch_stop_iteration
yield
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py", line 1081, in evaluate
tmp_logs = test_function(iterator)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/def_function.py", line 580, in __call__
result = self._call(*args, **kwds)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/def_function.py", line 650, in _call
return self._concrete_stateful_fn._filtered_call(canon_args, canon_kwds) # pylint: disable=protected-access
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/function.py", line 1665, in _filtered_call
self.captured_inputs)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/function.py", line 1746, in _call_flat
ctx, args, cancellation_manager=cancellation_manager))
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/function.py", line 598, in call
ctx=ctx)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/eager/execute.py", line 60, in quick_execute
inputs, attrs, num_outputs)
tensorflow.python.framework.errors_impl.OutOfRangeError: End of sequence
[[node IteratorGetNext (defined at home/train.py:55) ]] [Op:__inference_test_function_1055]
Function call stack:
test_function
File "/home/train.py", line 413, in <module>
main_function()
File "/home/train.py", line 358, in main_function
X_train, X_test, Y_train, Y_test, len(X_train), classes)
File "/home/train.py", line 55, in train_model
model.fit(train_dataset, epochs=100, validation_data=validation_dataset, verbose=2, callbacks=callbacks)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py", line 66, in _method_wrapper
return method(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py", line 872, in fit
return_dict=True)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/training.py", line 1088, in evaluate
callbacks.on_test_batch_end(step, logs)
File "/usr/local/lib/python3.7/contextlib.py", line 130, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.7/site-packages/tensorflow/python/keras/engine/data_adapter.py", line 1153, in catch_stop_iteration
self._inferred_steps))
TypeError: unsupported operand type(s) for *: 'int' and 'NoneType'
Job failed (see above)
I downgraded from 1.7.0 to 1.6.6 and still I am facing error.
Kindly advise on how to handle this scenario.
