AnaVij
February 26, 2021, 12:26pm
#1
Hi:
Need help for Edge Impulse installation. I am facing some issues in setting up the Arduino Nano 33 BLE for Edge Impulse. I am following the instructions in https://docs.edgeimpulse.com/docs/arduino-nano-33-ble-sense
Using Windows 10, and I get the following error while updating the firmware:
Finding Arduino Mbed core...
Installing Arduino Mbed core...
Downloading missing tool builtin:ctags@5.8-arduino11...
builtin:ctags@5.8-arduino11 already downloaded
Installing builtin:ctags@5.8-arduino11...
Error updating index: invalid handle
Error installing: creating instance: installing builtin:ctags@5.8-arduino11 tool: installing
tool builtin:ctags@5.8-arduino11: moving extracted archive to destination dir: rename
C:\Users\HP\AppData\Local\Arduino15\tmp\package-748038271\ctags-5.8-arduino11
C:\Users\HP\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11:
Access is denied.
Installing Arduino Mbed core OK
Finding Arduino Mbed core OK
Finding Arduino Nano 33 BLE...
Error detecting boards: creating instance: installing builtin:ctags@5.8-arduino11 tool:
installing tool builtin:ctags@5.8-arduino11: moving extracted archive to destination dir:
rename C:\Users\HP\AppData\Local\Arduino15\tmp\package-552121183\ctags-5.8-
arduino11 C:\Users\HP\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-
arduino11: Access is denied.
Cannot find a connected Arduino Nano 33 BLE development board via 'arduino-cli
board list'
If your board is connected, double-tap on the RESET button to bring the board in
recovery mode
Press any key to continue . . .
aurel
February 26, 2021, 12:40pm
#2
Hi @AnaVij ,
As there are some “access is denied” error logs, can you right click the flash_windows script and select run as an administrator ?
Also, which Arduino CLI version have you installed?
Thanks,
AnaVij
February 26, 2021, 12:55pm
#3
No change with run as administrator
I’m using arduino-cli_0.13.0_Windows_64bit
Also, I tried the update-index https://arduino.github.io/arduino-cli/getting-started/ and got the following message
arduino-cli core update-index
aurel
February 26, 2021, 1:01pm
#4
Thanks for the feedback, that looks like an arduino-cli install issue.
Can you paste logs using “-v” option: arduino-cli core update-index -v?
You can also try by starting a terminal as an admin user and run the same command.
AnaVij
February 26, 2021, 1:09pm
#5
C:\Users\HP>arduino-cli core update-index -v
INFO[0000] Using config file: C:\Users\HP\AppData\Local\Arduino15\arduino-cli.yaml
INFO[0000] arduino-cli version 0.13.0
INFO[0000] Checking signature
index="C:\\Users\\HP\\AppData\\Local\\Arduino15\\package_index.json"
signatureFile="C:\\Users\\HP\\AppData\\Local\\Arduino15\\package_index.json.sig"
trusted=true
INFO[0000] Checking if CLI is Bundled into the IDE
INFO[0000] Loading hardware from: C:\Users\HP\AppData\Local\Arduino15\packages
INFO[0000] Loading package builtin from:
INFO[0000] Checking existence of 'tools' path:
INFO[0000] Loading tools from dir:
INFO[0000] Loading package esp8266 from:
C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\hardware
INFO[0000] Loaded platform platform="esp8266:esp8266@2.3.0"
C:\Users\HP\AppData\Local\Arduino15\packages\esp8266\tools
INFO[0000] Loaded tool tool="esp8266:esptool@0.4.9"
INFO[0000] Loaded tool tool="esp8266:mkspiffs@0.1.2"
INFO[0000] Loaded tool tool="esp8266:xtensa-lx106-elf-
gcc@1.20.0-26-gb404fb9-2"
INFO[0000] Adding libraries dir
dir="C:\\Users\\HP\\Documents\\Arduino\\libraries" location=user
INFO[0000] Adding libraries dir dir="C:\\Users\\HP\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\2.3.0\\libraries" location=platform
INFO[0000] Installing tool Tool="builtin:ctags@5.8-arduino11"
WARN[0000] Cannot install tool Tool="builtin:ctags@5.8-arduino11"
error="moving extracted archive to destination dir: rename
C:\\Users\\HP\\AppData\\Local\\Arduino15\\tmp\\package-921151103\\ctags-5.8-
arduino11
C:\\Users\\HP\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-
arduino11: Access is denied."
INFO[0000] Executing `arduino core update-index`
ERRO[0000] Error updating index: invalid handle
There is no difference even with admin terminal
aurel
February 26, 2021, 1:41pm
#6
Are you logged in with the user “HP” on your computer?
Otherwise it is worth asking on the Arduino forum
AnaVij
March 1, 2021, 5:59am
#7
I got this fixed. The issue was with the antivirus software.
I turned it off during the install.
Thanks @aurel
