I am having the same problem that I have seen reported here by others, but the solutions offered haven’t worked for me. I am running Mac OS Big Sur 11.4, node.js v16.4.0. I followed the steps offered in the tutorial (https://github.com/edgeimpulse/example-SparkFun-MicroMod-nRF52840) until I try this: edge-impulse-data-forwarder --clean
I get the following error:
/usr/local/lib/node_modules/edge-impulse-cli/node_modules/bindings/bindings.js:135
throw err;
Error: Could not locate the bindings file. Tried:
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/Debug/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/Release/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/out/Debug/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/Debug/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/out/Release/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/Release/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/default/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/compiled/16.4.0/darwin/x64/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
→ /usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/lib/binding/node-v93-darwin-x64/bindings.node
at bindings (/usr/local/lib/node_modules/edge-impulse-cli/node_modules/bindings/bindings.js:126:9)
at Object. (/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/lib/darwin.js:2:36)
at Module._compile (node:internal/modules/cjs/loader:1095:14)
at Object.Module._extensions…js (node:internal/modules/cjs/loader:1124:10)
at Module.load (node:internal/modules/cjs/loader:975:32)
at Function.Module._load (node:internal/modules/cjs/loader:816:12)
at Module.require (node:internal/modules/cjs/loader:999:19)
at require (node:internal/modules/cjs/helpers:93:18)
at Object. (/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/lib/index.js:10:22)
at Module._compile (node:internal/modules/cjs/loader:1095:14) {
tries: [
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/Debug/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/Release/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/out/Debug/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/Debug/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/out/Release/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/Release/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/build/default/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/compiled/16.4.0/darwin/x64/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node’,
‘/usr/local/lib/node_modules/edge-impulse-cli/node_modules/@serialport/bindings/lib/binding/node-v93-darwin-x64/bindings.node’
I have tried uninstalling and reinstalling edge-impulse-cli and rebooting several times to no avail.
please advise.
