I have no idea what the solution to this error would be. Any tips?
Creating job… OK (ID: 1352112)
Writing templates OK
Scheduling job in cluster…
Building firmware…
tookchain file /app/firmware-ai-vision/Platform/ECM3532/M3/ECM35xx_toolchain.cmake
LINKER_SCRIPT /app/firmware-ai-vision/Platform/ECM3532/M3/scripts/linker/flash_shm.ld.S
building csp from src
– Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
Doxygen not found
board : ai_vision
dspfw /app/firmware-ai-vision/Platform/ECM3532/M3/util/dsp_fw/dsp_fw_pdm.bin
Wrote: /app/firmware-ai-vision/Platform/ECM3532/M3/…/…/…/Applications/edge-impulse-ingestion/edge-impulse-ingestion.emProject
Inc path :: edge-impulse-ingestion
– Configuring done
– Generating done
– Build files have been written to: /app/firmware-ai-vision/Applications/edge-impulse-ingestion/build
[ 0%] Built target ldconf
[ 2%] Built target freertos
[ 4%] Built target rpc
[ 4%] Built target autoconf
[ 4%] Built target ses
[ 9%] Built target csp
[ 11%] Built target hal
[ 12%] Built target iodev
[ 14%] Built target eta_ai_bsp
Scanning dependencies of target edgeimpulse
[ 14%] Building CXX object CMakeFiles/edgeimpulse.dir/app/firmware-ai-vision/Thirdparty/edge_impulse/tflite-model/trained_model_compiled.cpp.o
Job started
[ 14%] Linking CXX static library /app/firmware-ai-vision/Platform/ECM3532/M3/pre_built/libedgeimpulse.a
[ 94%] Built target edgeimpulse
Scanning dependencies of target edge-impulse-ingestion.elf
[ 94%] Building CXX object CMakeFiles/edge-impulse-ingestion.elf.dir/src/ei_run_impulse.cpp.o
[ 94%] Linking CXX executable edge-impulse-ingestion.elf
/gcc-arm-none-eabi-8-2018-q4-major/bin/…/lib/gcc/arm-none-eabi/8.2.1/…/…/…/…/arm-none-eabi/bin/ld: edge-impulse-ingestion.elf section .text' will not fit in region FLASH’
/gcc-arm-none-eabi-8-2018-q4-major/bin/…/lib/gcc/arm-none-eabi/8.2.1/…/…/…/…/arm-none-eabi/bin/ld: section .dspBlock LMA [000000000106a000,000000000107f1f9] overlaps section .text LMA [0000000001006000,00000000010b3c5b]
/gcc-arm-none-eabi-8-2018-q4-major/bin/…/lib/gcc/arm-none-eabi/8.2.1/…/…/…/…/arm-none-eabi/bin/ld: region `FLASH’ overflowed by 324208 bytes
CMakeFiles/edge-impulse-ingestion.elf.dir/build.make:451: recipe for target ‘edge-impulse-ingestion.elf’ failed
make[2]: *** [edge-impulse-ingestion.elf] Error 1
make[1]: *** [CMakeFiles/edge-impulse-ingestion.elf.dir/all] Error 2
CMakeFiles/Makefile2:1984: recipe for target ‘CMakeFiles/edge-impulse-ingestion.elf.dir/all’ failed
make: *** [all] Error 2
Makefile:103: recipe for target ‘all’ failed
Application exited with code 2 (Error)
Job failed (see above)
