I could install the CLI tools succesfully, and update the firmware as suggested in the tutorial. But when I run the edge-impulse-run-impulse command the following error pops:
`assertion "(*input)->params.scale == EI_CLASSIFIER_TFLITE_INPUT_SCALE" failed: file erboard-sense-2\edgeimpulse/edge-impulse-sdk/classifier/ei_run_classifier.h", line Tensor**, uint8_t**)`
I think it should be something related to the firmware version or so. May you provide some advice?
Hallo @rjames, After a while I can finally test the code with the lastest github version( todays version : 29/11/2021) and I face the same error. Is it something to do with the ei_microphone.cpp file? I see like an error (even though it compiles) shown in the Simplicity studio environment.
