Error after training with FOMO
When I trained FOMO model, after the training, the project failed to save the results.
I have 100,000 images labeled.
Summary:
The error is as following:
/app/run-python-with-venv.sh: line 17:   773 Killed                  /app/$VENV_NAME/.venv/bin/python3 -u $ARGS
Application exited with code 137 (OOMKilled)
2025-01-09T16:17:01.049Z logger=server level=error Failed job execution
Error: Job 27874741 finished
    at /home/node/studio/build/server/server/start-daemon.js:264:48
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
Job failed (see above)
Steps to Reproduce:
  1. Create the images features 320x320
  2. Train the FOMO model
Expected Results:
Model should be saved
Actual Results:
Error while saving
  • [ X] Always
  • Platform: ESP32-EYE
  • Build Environment Details: Arduino 2.0.4
  • OS Version: Windows 10
Hi @yustiks
I don’t see why your project should be failing, kick off training again and see. Perhaps it was an intermittent issue on the server side, there may have been security patching etc. I will flag this to our infra. cc @ferjm_ei
Not 100% you are in an enterprise trial, are you working with any of the solutions team on this? I cant see any config issue on the project @jimbruges or @yodaimpulse can one of you check out this project?
