Scheduling job in cluster…
Job started
Reducing dimensions for visualizations…
UMAP(n_components=3, verbose=True)
/usr/local/lib/python3.7/dist-packages/umap/umap_.py:1679: UserWarning: n_neighbors is larger than the dataset size; truncating to X.shape[0] - 1
"n_neighbors is larger than the dataset size; truncating to "
Construct fuzzy simplicial set
Sat Apr 30 02:13:25 2022 Finding Nearest Neighbors
Sat Apr 30 02:13:27 2022 Finished Nearest Neighbor Search
Still running…
Sat Apr 30 02:13:30 2022 Construct embedding
ERR: zero-size array to reduction operation maximum which has no identity
Job failed (see above)
Hi!whats the problem?
