Project ID: 290646
I have a 8x8 thermal sensor which I am using for gesture recognition. I wanted to change run_classifier() to run_classifier_continuous(), and I am receiving this error:
ERR: Unknown extract function, only MFCC, MFE and spectrogram supported
Does that mean the continuous classifier only works with audio? I need to work with raw data for my project.
I just replaced the run_classifier() function and did not change anything else.
Below is my code for the data extraction and classification if it matters.
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/sensor.h>
#include "edge-impulse-sdk/dsp/numpy.hpp"
#include <zephyr/sys/printk.h>
#include <stdio.h>
#define FREQUENCY_HZ EI_CLASSIFIER_FREQUENCY
#define INTERVAL_MS (1000 / (FREQUENCY_HZ + 1))
size_t feature_ix = 0;
static float features[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE]={0};
return 0;
static struct sensor_value temp_value[64];
float sensor_array[64]={0};
int maxnow = 0;
int minnow = 25;
int cycle = 1;
int max = 0;
int min=0;
float ftemp=0;
int limlow = 24; //lower cutoff temperature
int body = 33; //max temperature to amplify
#ifdef CONFIG_AMG88XX_TRIGGER
K_SEM_DEFINE(sem, 0, 1);
static void trigger_handler(const struct device *dev,
const struct sensor_trigger *trigger)
ARG_UNUSED(dev);
ARG_UNUSED(trigger);
k_sem_give(&sem);
#endif
void print_buffer(void *ptr, size_t l, float *arr)
struct sensor_value *tv = (sensor_value*)ptr;
maxnow = 0;
minnow = 25;
int temp1 = 0 ;
int temp2 = 0 ;
for (int i = 0; i < l; i++) {
temp1 = (tv[i].val1);
temp2 = (tv[i].val2 / 10000);
// compare values to find maximum and minimum in one iteration
if (temp1 > maxnow && temp1 < body) {
maxnow = temp1;
if (temp1 < minnow) {
minnow = temp1;
// cutoff values below defined lower limit
/*if (temp1 <= limlow) {
temp1 = limlow;
temp2 = 0;
// set values out of range to 0
if (temp1 > (max + 1) || temp1 < (max - 2)) {
temp1 = 0;
temp2 = 0;
if (temp1 <= (min + 3)) {
temp1 = 0;
temp2 = 0;
else {
//temp1 = (temp1 - (min + 3));
temp1 = 55;
float ft1 = temp1;
float ft2 = temp2;
ftemp = ft1 + (ft2 / 100);
arr[i] = ftemp;
// set max and min temperature of last iteration for the next one
max = (maxnow);
min = (minnow);
int main(void)
int ret;
setvbuf(stdout, NULL, _IONBF, 0);
const struct device *dev = device_get_binding(
DT_LABEL(DT_INST(0, panasonic_amg88xx)));
if (dev == NULL) {
printk("Could not get AMG88XX device\n");
return 1;
printk("device: %p, name: %s\n", dev, dev->name);
struct sensor_value attr = {
.val1 = 27,
.val2 = 0,
if (sensor_attr_set(dev, SENSOR_CHAN_AMBIENT_TEMP,
SENSOR_ATTR_UPPER_THRESH, &attr)) {
printk("Could not set threshold\n");
return;
struct sensor_trigger trig = {
.type = SENSOR_TRIG_THRESHOLD,
.chan = SENSOR_CHAN_AMBIENT_TEMP,
if (sensor_trigger_set(dev, &trig, trigger_handler)) {
printk("Could not set trigger\n");
return;
#endif
while (42) {
printk("Waiting for a threshold event\n");
k_sem_take(&sem, K_FOREVER);
#endif
ret = sensor_sample_fetch(dev);
if (ret) {
printk("Failed to fetch a sample, %d\n", ret);
return 1;
ret = sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP,
(struct sensor_value *)temp_value);
if (ret) {
printk("Failed to get sensor values, %d\n", ret);
return 1;
print_buffer(temp_value, ARRAY_SIZE(temp_value), sensor_array);
for (int i=0; i<64; i++) {
printf("%f", sensor_array[i]);
if (i<63) {
printf(",");
printf("\n");
k_sleep(K_MSEC(45));
if (sizeof(features) / sizeof(float) != EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
printk("The size of your 'features' array is not correct. Expected %d items, but had %u\n",
k_msleep(83);
features[feature_ix++] = sensor_array[i];
if (feature_ix == EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
signal_t signal;
numpy::signal_from_buffer(features, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
// Run classifier
EI_IMPULSE_ERROR res = run_classifier_continuous(&signal, &result, false);
//ei_printf("run_classifier returned: %d\n", res);
if (res != 0) return 0;
// Print predictions
/*ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
ei_printf("%s:\t%.5f\n", result.classification[ix].label, result.classification[ix].value);
// reset features frame
feature_ix = 0;
return 0;
