Hi
I m using the ST b-l475e-iot01a dev board to do some data acquisition with the built-in accelerometer.
I could not upload the data. Could you please help ? Thanks, Julien
Hi
Hi @Juph, I assume you have followed all the steps in: https://docs.edgeimpulse.com/docs/unboxing-the-st-b-l475e-iot01a? Are you able to connect with the edge-impulse-daemon successfully?
It seems that I could not ? Thanks.
C:\Users\Utilisateur>edge-impulse-daemon
C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\bindings\bindings.js:135
throw err;
Error: Could not locate the bindings file. Tried:
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\build\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\build\Debug\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\build\Release\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\out\Debug\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\Debug\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\out\Release\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\Release\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\build\default\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\compiled\14.17.6\win32\x64\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\addon-build\release\install-root\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\addon-build\debug\install-root\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\addon-build\default\install-root\bindings.node
→ C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\lib\binding\node-v83-win32-x64\bindings.node
at bindings (C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\bindings\bindings.js:126:9)
at Object. (C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\lib\win32.js:1:36)
at Module._compile (internal/modules/cjs/loader.js:1072:14)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1101:10)
at Module.load (internal/modules/cjs/loader.js:937:32)
at Function.Module._load (internal/modules/cjs/loader.js:778:12)
at Module.require (internal/modules/cjs/loader.js:961:19)
at require (internal/modules/cjs/helpers.js:92:18)
at Object. (C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules@serialport\bindings\lib\index.js:6:22)
at Module._compile (internal/modules/cjs/loader.js:1072:14) {
tries: [
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\Debug\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\Release\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\out\Debug\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\Debug\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\out\Release\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\Release\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\build\default\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\compiled\14.17.6\win32\x64\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\addon-build\release\install-root\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\addon-build\debug\install-root\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\addon-build\default\install-root\bindings.node’,
‘C:\Users\Utilisateur\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\@serialport\bindings\lib\binding\node-v83-win32-x64\bindings.node’
Hi @Juph, this means that the edge impulse CLI tools was not successfully installed, which is a must. The problem appears because it is likely you did not select to install the “Additional node.js tools” when you installed node.js. Selecting this option during the node.js installation process is very important.
It is also assumed that you have installed Python 3 prior to performing these steps. You can check at the command prompt by running: python3 --version
Then, please try the following:
