Hi everyone, I’m trying to process object detection on ESP-32 Cam Wrover.
After uploading the Arduino Library on the Arduino IDE and runing the “esp32_cam” sketch from the examples, I get this error :
ERR: Failed to allocate snapshot buffer! coming from this :
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
#define EI_CAMERA_FRAME_BYTE_SIZE 3
if(snapshot_buf == nullptr) {
return;
Project ID: 174736
My peak ram usage is only 4Kb, I can’t figure what’s the problem…
Anyone could help with this ? Than you
I do not know how much RAM the ESP-32 Cam Wrover has but where do you see Peak RAM usage as 4kiB. It takes 320 x 240 x 3 = 230.4kiB RAM to store the image that is a mere 57 times the reported Peak RAM usage.
I suggest reducing the Impulse Input Data Block to maybe 96x96.
rjames
January 29, 2023, 7:42am
#3
@Clem_gro
What @MMarcial suggests is correct. It must be that the size of your model + snapshot buffer is more RAM than is currently available on the ESP-32 Cam Wrover.
Unfortunately the 4kB Peak RAM usage is incorrect and I’ll create a ticket. Thanks for reporting
The ESP-32 is supposed to have 8MB of RAM, how is not this enough ?
After changing Impulse Data Block to 48x48 and those lines :
By those lines :
#define EI_CAMERA_RAW_FRAME_BUFFER_COLS 48
#define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 48
This is what I get in the serial monitor :
Edge Impulse Inferencing Demo
Camera initialized
Starting continious inference in 2 seconds...
Guru Meditation Error: Core 1 panic'ed (LoadStoreError). Exception was unhandled.
Core 1 register dump:
PC : 0x400df772 PS : 0x00060430 A0 : 0x80100f75 A1 : 0x3ffb1c60
A2 : 0x3ffc8784 A3 : 0x40000044 A4 : 0x000003c0 A5 : 0x00000010
A6 : 0x00000008 A7 : 0x3ffc4d64 A8 : 0x00000000 A9 : 0x00000002
A10 : 0x00000072 A11 : 0x40000044 A12 : 0x00000030 A13 : 0x000378c0
A14 : 0x00038400 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000003
EXCVADDR: 0x40000044 LBEG : 0x40089854 LEND : 0x40089870 LCOUNT : 0x00000000
ELF file SHA256: 0000000000000000
Backtrace: 0x400df772:0x3ffb1c60 0x40100f72:0x3ffb1c80 0x40061b1b:0x3ffb1ca0 0x400e4823:0x3ffb1d20 0x400df6d5:0x3ffb1de0 0x400df7d9:0x3ffb1e10 0x400d2478:0x3ffb1e50 0x400d3173:0x3ffb1e70 0x400dba85:0x3ffb1fb0 0x4008c44e:0x3ffb1fd0
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
After using Esp Exception Decoder, I get this information :
What did I do wrong ?
Is it ok to set my Impulse Data Block to 48x48 with the MobileNetV1 96x96 0.1 ?
No, you should not change the
RAW_FRAME_BUFFER
values, unless you also change .frame_size in camera_config. So just leave them as is and try to run your impulse.
Do you have PSRAM enabled?
According to this discussion on the espressif forum , the ESP32 Wrover automatically set the PSRAM to “enable”. Could you confirm that ?
Anyway, when selecting the module ESP32-CAM Wrover module on the Arduino IDE, no option allows me to enable or not the PSRAM :
When putting back the RAW_FRAME_BUFFER to their initials values, I got the same error again :
Any idea ?
louis
February 2, 2023, 5:08am
#7
Hi!
Can you try to use the ESP32 Dev Module as the board?
Let me know if that works
when training the model, what dimensions did you set if the size of the pre-training was large, this may not fit
Hello!
Have you been able to resolve the issue?
I solved the problem just by updating the version of Arduino IDE.
Sometimes it is just that simple
Thanks for all the people that helped me with this !
Hello, I hope you can help me, which version did you update to remove the error?
“ERR: Failed to allocate snapshot buffer", I have the latest version installed and I cannot solve the problem
hi there,
if you are still experiencing issues, please go to the block that looks like this:
you need to reduce the values for EI_CAMERA_RAW_FRAME_BUFFER_COLS and EI_CAMERA_RAW_FRAME_BUFFER_ROWS
96 worked for me.
kind regards,
rey malahay
