I have a project which takes inputs as raw data and is then fed directly into the neural network.
I want to use the EON tuner to find the best model. However, the EON tuner fails to run with the following error:
The data here is ECG signal which is represented in float values in volts. I had uploaded it using ingestion API in form of JSON files. I would like to understand how the EON tuner identifies the project as audio or accelerometer type?
What changes shall I do in the data format so that, the EON tuner considers the data for tuning? Here is a snippet for your reference:
Thanks for reporting this issue, i’ve identified the cause and I will deploy a fix for this tomorrow at latest. I’ll post an update here as soon as the fix is live.
