EON Tuner - failing to generate DSP block train features
EON tuner is failing when generating train features for the DSP block. Other aspects of the project appear to be working ok.
  • Workers | Ready: 0 Busy: 0 Pending: 0
  • Trials | Pending: 28 Running: 2 Completed: 0 Failed:0 Retried: 36
  • Completed | DSP: 0 Learn: 0
  • Time | 1666507866
Generating train features for DSP block 1427594
Will retry trial 4e3e2478-0aef-4015-9615-6d97d023225b failed: Block dsp failed
Generating train features for DSP block 1427596
Will retry trial 4cbe08dd-ab34-47a5-88ca-f240528cecf4 failed: Block dsp failed
Generating train features for DSP block 1427599
thanks!
Hello @imuc,
I just created a version of your project called “Edge Impulse Support” so one of our Core Engineer can have a deeper look as I don’t see any misconfiguration issue.
Ok great. Thank you!!
Hi Louis … fyi - I resampled my audio data from 44k to 8k and was able to perform EON tuning without a problem against the same model … and I’m getting close the same score results.
thanks
