Creating job… OK (ID: 2037795)
Job failed (see above)
Hello @nlbutts42,
I would need more details to understand your issue
What kind of project are you working on?
Which parameters did you set for the EON tuner?
Do you have a project ID or your project name so I can have a look at your project? (I see two projects under your account)
Best regards,
Sorry. It is the First Robotics project. I’m trying to train an object detector. I’ve uploaded 183 images and have trained the network. I then tried to run the EON tuner but I just get the really generic error.
Nothing else. So I have no idea why it failed.
Hello @nlbutts42,
Ok I just had a look at your project and you are working on an object detection project, not image classification.
Indeed EON Tuner is not yet compatible with Object Detection. It is only for Image Classification.
We are working on an EON tuner-compatible object detection feature but I don’t have any ETA at the moment.
I have just updated our documentation to mark the supported project types in bold for more clarity:
I’ll also check internally if we can add clearer error messages in the logs.
