我在平台上训练了一个对象检测模型,设置的图像格式是300x300的RGB,对象检测页面神经网络架构显示输入特征为270000,选择 Linux (AARCH64)部署后生成的screw.eim文件在树莓派上运行显示Invalid number of features in ‘classify’, expected 90000 but got 270000
Hi @WEIWEIWEI
You will need to match the features to your project if you have 90000 in the code and dont match the 270000 from the project this error will happen.
