According to EdgeImpulse documentation, here are the steps to upload your own labeled data.
- Annotate the target objects and save them in the provided JSON format. (Or alternatively, you can convert from other formats. Here are a few examples of how to convert).
- Rename the JSON file to “bounding_boxes.labels” and place it in the same folder where the images are.
- Upload the images together with the label file from the Studio.
But this doesn’t work. You get errors:
Error #1: If you named the label file “bounding_boxes.labels” as described in the documentation, the uploader does not recognize the extension and thus will not upload the label file. Ouch!
[1/1] Failed to process bounding_boxes.labels: extension not supported (only .wav, .cbor, .json, .jpg, .jpeg, .png, .mp4 and .csv supported)
Error #2: If you play smart and add JSON extension “bounding_boxes.labels.json”, you will get a different error.
[1/1] Failed to upload bounding_boxes.labels.json Missing protected header
