EdgeImpulse on RPI Linux: 32 vs 64 bit?
We are running EI for Gesture and voice recognition on RPI Zero 2.
What are people insights regarding using the 32bit vs 64bit rpi os versions?
Hi @ramfish ,
Interesting topic!
The inferencing should run faster on 64bit, personally not tested this yet though, let me check with the team to see what others experience was.
@jorduino Are you saying the Edge Impulse inferencing should run faster on 64-bit RPI because the deployed Edge Impulse library has 32-bit and 64-bit compiler directives within the code and as such can take advantage of 64-bit?
Hi @MMarcial
The method was described in this post, adding a link to save duplication, and we can continue there if needed :slight_smile:
