Hi all
I have an ESP32-WROVER board. what Edge supported board is compatible with it?
at the moment am getting the following response from my ESP32-WRover board:
03:51:03.380 -> ERR: Camera is not initialized
03:51:03.380 -> Failed to capture image
UPDATE: 2024/01/25
this is the message the appears when the board first initializes.
11:13:57.763 -> Edge Impulse Inferencing Demo
11:13:57.763 -> E (40) camera: Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND)
11:13:57.763 -> Camera init failed with error 0x105
11:13:57.763 -> Failed to initialize Camera!
thanks in advance,
rey malahay
Hi @reymalahay,
The ESP32-WROVER is not officially supported by Edge Impulse. As a result, you will need to export the Edge Impulse project as an Arduino library or a C++ library. From there, you will need to write code to capture an image from the camera, scale/crop as needed, and call run_classifier(). If you use the Arduino library, it comes with a number of examples. If you use ESP-IDF, then you can use this example to see how to import the C++ library.
hi @shawn_edgeimpulse ,
thank you for the response. i’ll take a look. i will mark your response as the solution, until such time that Edge Impulse supports the ESP32-WRover board.
kind regards,
rey malahay
