After setting up env in Linux for openmv from below link:
When I run the below script
edge-impulse-uploader --format-openmv path
it give error
edge-impulse-uploader: command not found
" I am uploading dataset through CLI to EdgeImpulse"
it give error
Hi @wamiq.raza,
First check if the CLI is properly installed. You can do this by running $ edge-impulse-daemon and see if it throws any errors.
Let me know if this helps.
Clinton
Hi@oduor_c ,
Can you tell me when the OPENMV library is expected to be released? Thank you very much.
Hello @pkqxlh ,
I cannot give you a rock-solid release date for now, we will update this thread when it will be released!
