I have installed edge impulse on raspberry pi and am currently trying to create inference on raspberry pi but when i run my code on the terminal i keep getting this error:
ImportError: No module named edge_impulse_linux.runner
Hi @obioheme
What steps did you take when installing?
pip3 install edge_impulse_linux -i https://pypi.python.org/simple
Yes I used that when installing and I even did it again and it showed “requirement already satisfied” for edge_impulse_linux version 1.0.8, psutil 5.9.5 and numpy 1.21.6
Hi @obioheme
Can you give the specific commands and tutorial that you are following? Python and pip can be a minefield.
There are many areas where people miss steps or use the wrong command and most are hopefully already on the forum/docs.
If perhaps you are following an external guide or missed a step please share the commands and steps.
This was the setup tutorial i used for the installation
sudo apt update
curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
sudo apt install -y gcc g++ make build-essential nodejs sox gstreamer1.0-tools gstreamer1.0-plugins-good gstreamer1.0-plugins-base gstreamer1.0-plugins-base-apps
npm config set user root && sudo npm install edge-impulse-linux -g --unsafe-perm
When I tried installing the second code from nodesource, node 12x it said the file had depreciated.
