Edge Impulse Now Supports Classical ML Models from Scikit-Learn
By default, Edge Impulse supports neural networks (deep learning) for most of its classification and regression models. While these are great for complex problems, they are often computationally expensive and difficult to train. Sometimes, you need a simpler solution, which means you can run with lower power and reduce BOM costs!
This is a companion discussion topic for the original entry at https://www.edgeimpulse.com/blog/edge-impulse-now-supports-classical-ml-models/
