Edge Impulse Inferencing Demo Error Message
When running the generated nano_ble33_sense_accelerometer data, I run into ERR: EI_CLASSIFIER_RAW_SAMPLES_PER_FRAME should be equal to 3 (the 3 sensor axes). It doesn’t fail, just prints out the error, but I was wondering if it’s something on my end that the sensors used are 9 (shown in picture) rather than the 3 accelerometer axes.
Is there a way to specify to use only the accelerometer data when training the model? I’ve been following the coursera intro to embedded ML and ran into this issue.
This issue is currently being investigating by our embedded engineering team.
You can modify the model_metadata.h in the meantime, it should fix your issue
Yes you can select which axis you need in the pre-processing block if you only want to use accX, acc,Y and accZ for example.
Also note that you can try to run the sensor_fusion example.
