Hi I am facing error in uploading a single axis data on edge Impulse.
$ edge-impulse-data-forwarder --clean
Edge Impulse data forwarder v1.6.2
This is an experimental feature, please let us know if you run into any issues at
https://forum.edgeimpulse.com
? What is your user name or e-mail address (edgeimpulse.com)? paulphilip
? What is your password? [hidden]
Endpoints:
[SER] Connecting to COM3
[SER] Serial is connected
? To which project do you want to add this device? testDataUpload
? What name do you want to give this device?xxxxxxxxxxxxxxxxxxxxxxxxxxx
[WS ] Authenticated
path: '/api/training/data',
label: 'Sine1Hz',
length: 15000,
interval: 16.129032258064516,
hmacKey: 'xxxxxxxxxxxxxxxxxx',
sensor: 'Sensor with 1 axes ()'
[SER] Waiting 2 seconds...
[SER] Reading data from device...
[SER] Reading data from device OK (906 samples at 62Hz)
[SER] Uploading sample to https://ingestion.edgeimpulse.com/api/training/data...
[SER] Failed to sample data StatusCodeError: 400 - "Sensors should have { name: string, units: string }, but are missing for one or more axes ([{\"name\":\"\",\"units\":\"N/A\"}])"
at new StatusCodeError (C:\Users\Z0040vnh\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request-promise-core\lib\errors.js:32:15)
at Request.plumbing.callback (C:\Users\Z0040vnh\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request-promise-core\lib\plumbing.js:104:33)
at Request.RP$callback [as _callback] (C:\Users\Z0040vnh\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request-promise-core\lib\plumbing.js:46:31)
at Request.self.callback (C:\Users\Z0040vnh\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request\request.js:185:22)
at Request.emit (events.js:310:20)
at Request.<anonymous> (C:\Users\Z0040vnh\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request\request.js:1154:10)
at IncomingMessage.<anonymous> (C:\Users\Z0040vnh\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules\request\request.js:1076:12)
at Object.onceWrapper (events.js:416:28)
at IncomingMessage.emit (events.js:322:22)
at endReadableNT (_stream_readable.js:1187:12)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
statusCode: 400,
error: 'Sensors should have { name: string, units: string }, but are missing for one or more axes ([{"name":"","units":"N/A"}])', options: {
headers: {
'x-api-key': 'ei_xxxxxxxxxxxxxxxxxxxxxxxxxxx',
'x-file-name': 'Sine1Hz.json',
'x-label': 'Sine1Hz',
'Content-Type': 'application/json'
body: '{"protected":{"ver":"v1","alg":"HS256","iat":1590653804},"signature":"ba025a592f576df1cc433cbb57df5a313c6da9e8a3b05d614e99700aaf5ef9b6","payload":{"device_name":"06:6C:FF:36:39:31:59:4E:43:03:37:06","device_type":"DATA_FORWARDER","interval_ms":16.129032258064516,"sensors":[{"name":"","units":"N/A"}],"values":[[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[-1790],[-1864],[-1917],[-1949],[-1960],[-1949],[-1917],[-1864],[-1790],[-1697],[-1585],[-1456],[-1311],[-1152],[-980],[-797],[-605],[-407],[-204],[0],[204],[407],[605],[797],[979],[1152],[1311],[1456],[1585],[1697],[1790],[1864],[1917],[1949],[1960],[1949],[1917],[1864],[1790],[1697],[1585],[1456],[1311],[1152],[979],[797],[605],[407],[204],[0],[-204],[-407],[-605],[-797],[-980],[-1152],[-1311],[-1456],[-1585],[-1697],[0]]}}',
encoding: 'binary',
uri: 'https://ingestion.edgeimpulse.com/api/training/data',
method: 'POST',
callback: [Function: RP$callback],
transform: undefined,
simple: true,
resolveWithFullResponse: false,
transform2xxOnly: false
response: IncomingMessage {
_readableState: ReadableState {
objectMode: false,
highWaterMark: 16384,
buffer: BufferList { head: null, tail: null, length: 0 },
length: 0,
pipes: null,
pipesCount: 0,
flowing: true,
ended: true,
endEmitted: true,
reading: false,
sync: false,
needReadable: false,
emittedReadable: false,
readableListening: false,
resumeScheduled: false,
emitClose: true,
autoDestroy: false,
destroyed: false,
defaultEncoding: 'utf8',
awaitDrain: 0,
readingMore: false,
decoder: [StringDecoder],
encoding: 'latin1',
[Symbol(kPaused)]: false
readable: false,
_events: [Object: null prototype] {
end: [Array],
close: [Array],
data: [Function],
error: [Function]
_eventsCount: 4,
_maxListeners: undefined,
socket: TLSSocket {
_tlsOptions: [Object],
_secureEstablished: true,
_securePending: false,
_newSessionPending: false,
_controlReleased: true,
_SNICallback: null,
servername: 'ingestion.edgeimpulse.com',
alpnProtocol: false,
authorized: true,
authorizationError: null,
encrypted: true,
_events: [Object: null prototype],
_eventsCount: 10,
connecting: false,
_hadError: false,
_parent: null,
_host: 'ingestion.edgeimpulse.com',
_readableState: [ReadableState],
readable: true,
_writableState: [WritableState],
writable: false,
allowHalfOpen: false,
_sockname: null,
_pendingData: null,
_pendingEncoding: '',
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
_rejectUnauthorized: true,
parser: null,
_httpMessage: [ClientRequest],
[Symbol(res)]: [TLSWrap],
[Symbol(asyncId)]: 6363,
[Symbol(kHandle)]: [TLSWrap],
[Symbol(kSetNoDelay)]: false,
[Symbol(lastWriteQueueSize)]: 0,
[Symbol(timeout)]: null,
[Symbol(kBuffer)]: null,
[Symbol(kBufferCb)]: null,
[Symbol(kBufferGen)]: null,
[Symbol(kCapture)]: false,
[Symbol(kBytesRead)]: 0,
[Symbol(kBytesWritten)]: 0,
[Symbol(connect-options)]: [Object]
connection: TLSSocket {
_SNICallback: null,
authorized: true,
encrypted: true,
_eventsCount: 10,
connecting: false,
_hadError: false,
_parent: null,
readable: true,
writable: false,
_sockname: null,
_pendingData: null,
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
parser: null,
httpVersionMajor: 1,
httpVersionMinor: 1,
httpVersion: '1.1',
complete: true,
headers: {
date: 'Thu, 28 May 2020 08:16:45 GMT',
'content-type': 'text/plain',
'transfer-encoding': 'chunked',
connection: 'close',
'x-powered-by': 'Express',
'access-control-allow-origin': '*'
rawHeaders: [
'Date',
'Content-Type',
'text/plain',
'Transfer-Encoding',
'chunked',
'Connection',
'close',
'X-Powered-By',
'Express',
'Access-Control-Allow-Origin',
trailers: {},
rawTrailers: [],
aborted: false,
upgrade: false,
url: '',
method: null,
statusCode: 400,
statusMessage: 'Bad Request',
client: TLSSocket {
_SNICallback: null,
authorized: true,
encrypted: true,
_eventsCount: 10,
connecting: false,
_hadError: false,
_parent: null,
readable: true,
writable: false,
_sockname: null,
_pendingData: null,
server: undefined,
_server: null,
ssl: [TLSWrap],
_requestCert: true,
parser: null,
_consuming: true,
_dumped: false,
req: ClientRequest {
_eventsCount: 5,
outputData: [],
outputSize: 0,
writable: true,
_last: true,
chunkedEncoding: false,
shouldKeepAlive: false,
useChunkedEncodingByDefault: true,
sendDate: false,
_removedConnection: false,
_removedContLen: false,
_removedTE: false,
_contentLength: null,
_hasBody: true,
_trailer: '',
finished: true,
_headerSent: true,
socket: [TLSSocket],
connection: [TLSSocket],
_header: 'POST /api/training/data HTTP/1.1\r\n' +
'x-api-key: ei_xxxxxxxxxxxxxxxxxxxxxxxx\r\n' +
'x-file-name: Sine1Hz.json\r\n' +
'x-label: Sine1Hz\r\n' +
'Content-Type: application/json\r\n' +
'host: ingestion.edgeimpulse.com\r\n' +
'content-length: 6702\r\n' +
'Connection: close\r\n' +
'\r\n',
_onPendingData: [Function: noopPendingOutput],
agent: [Agent],
socketPath: undefined,
method: 'POST',
insecureHTTPParser: undefined,
_ended: true,
res: [Circular],
aborted: false,
timeoutCb: null,
upgradeOrConnect: false,
parser: null,
maxHeadersCount: null,
reusedSocket: false,
[Symbol(kNeedDrain)]: false,
[Symbol(corked)]: 0,
[Symbol(kOutHeaders)]: [Object: null prototype]
request: Request {
_eventsCount: 5,
headers: [Object],
encoding: 'binary',
uri: [Url],
method: 'POST',
readable: true,
writable: true,
explicitMethod: true,
_qs: [Querystring],
_auth: [Auth],
_oauth: [OAuth],
_multipart: [Multipart],
_redirect: [Redirect],
_tunnel: [Tunnel],
_rp_resolve: [Function],
_rp_reject: [Function],
_rp_promise: [Promise [Object]],
_rp_callbackOrig: undefined,
callback: [Function],
_rp_options: [Object],
setHeader: [Function],
hasHeader: [Function],
getHeader: [Function],
removeHeader: [Function],
localAddress: undefined,
pool: {},
dests: [],
__isRequestRequest: true,
_callback: [Function: RP$callback],
proxy: null,
tunnel: true,
setHost: true,
originalCookieHeader: undefined,
_disableCookies: true,
_jar: undefined,
port: 443,
httpModule: [Object],
agentClass: [Function: Agent],
agent: [Agent],
_started: true,
href: 'https://ingestion.edgeimpulse.com/api/training/data',
req: [ClientRequest],
ntick: true,
response: [Circular],
originalHost: 'ingestion.edgeimpulse.com',
originalHostHeaderName: 'host',
responseContent: [Circular],
_destdata: true,
_ended: true,
_callbackCalled: true,
toJSON: [Function: responseToJSON],
caseless: Caseless { dict: [Object] },
body: 'Sensors should have { name: string, units: string }, but are missing for one or more axes ([{"name":"","units":"N/A"}])',
Following is the error message shown in edge impulse studio
Kindly advise.
