Hi All,
While uploading the sensor data from my Arduino Nano board, I randomly keep seeing failures connecting to the device via ‘edge-impulse-daemon’ with the below messages, while the device is idle. Resetting the device resumes the connection and needs to re-start the sampling.
[SER] Failed to get info off device Error: Cannot parse sensor line: 100.00Hz]
at EiSerialProtocol.getConfig (/home/balaji/.npm-global/lib/node_modules/edge-impulse-cli/build/shared/daemon/ei-serial-protocol.js:136:31)
at async SerialConnector.connectLogic (/home/balaji/.npm-global/lib/node_modules/edge-impulse-cli/build/cli/daemon.js:483:26)
[SER] Failed to get info off device Error: Cannot parse sensor line: ]
at async Timeout.connectLogic [as _onTimeout] (/home/balaji/.npm-global/lib/node_modules/edge-impulse-cli/build/cli/daemon.js:456:22)
[SER] Serial closed - retrying in 5 seconds
Could you please share if this is a known behavior?
