DSP does not handle grayscale image efficiently
I am capturing single channel grayscale uint8_t data array from the image sensor. I am using quantized model and the run_classifier steps into the code (below) for DSP. Why is it expecting 1-channel data as RGB888? It is a waste of 2x memory size of the grayscale image. We can just use the uint8_t value as gray value.
ei_run_dsp.h: extract_image_features_quantized():
       int32_t r = static_cast<int32_t>(pixel >> 16 & 0xff);
       int32_t g = static_cast<int32_t>(pixel >> 8 & 0xff);
       int32_t b = static_cast<int32_t>(pixel & 0xff);
       int32_t gray = (iRedToGray * r) + (iGreenToGray * g) + (iBlueToGray * b);
       gray >>= 16; // scale down to int8_t
       gray += EI_CLASSIFIER_TFLITE_INPUT_ZEROPOINT;
       if (gray < - 128) gray = -128;
       else if (gray > 127) gray = 127;
       output_matrix->buffer[output_ix++] = static_cast<int8_t>(gray);
It’s a good question, we’re doing this so we have a consistent signal across all sensor types. The memory overhead is not that bad as you imagine, as you can do this on the fly with the signal_t. Your internal buffer is int8, we then dynamically convert when needed. See e.g. https://github.com/edgeimpulse/example-signal-from-rgb565-frame-buffer which has RGB565 framebuffer and then converts on the fly. We do this on fully supported dev boards already to save RAM.
Thanks for the link! Below function converts rgb565 to rgb in the given code:
void r565_to_rgb(uint16_t color, uint8_t *r, uint8_t *g, uint8_t *b) {
    *r = (color & 0xF800) >> 8;
    *g = (color & 0x07E0) >> 3;
    *b = (color & 0x1F) << 3;
Although it does not make sense but what would be the equivalent function for grayscale to rgb? Will the function below work?
void grayscale_to_rgb(uint8_t gray, uint32_t *r, uint32_t *g, uint32_t *b) {
    *r = gray<<16;
    *g = gray<<8;
    *b = gray;
Or,
void grayscale_to_rgb(uint8_t gray, uint32_t *rgb) {
    *rgb = (gray<<16) | (gray<<8) | gray;
    *r = gray;
    *g = gray;
    *b = gray;
This would work I guess :slight_smile:
OK, let me try it. By the way, is there any example using grayscale camera?
Yeah, see https://github.com/edgeimpulse/firmware-himax-we-i-plus/blob/03847d1f328d14af7f42952d564b9771ea7a6fd6/sensors/ei_camera.cpp#L560 for example.
