Hello
I use a small jupyter notebook to upload a MNIST dataset of handsigns.
The dataset is a csv file containing around 34.000 datapoints which each contain 784 samples, 28x28 pixels.
I can upload them to Edge Impulse Studio, however when i go into the image preprocessing block the DSP result outputs the following:
Error: The specified key does not exist.
I think your issue come from the image format which is not accepted by Edge Impulse. For images, we only work with .jpg or .png.
In that case, I would create a simple Python script that convert the csv rows to png/jpg image and use our API/CLI to upload the images to your project.
Hey @louis
Thanks for the reply!
Yea i figured that out as well after some time, and did end up making a Python script which convert the whole CSV into to png, which i uploaded through the API with great succes!
Are there any plans to expand the ingestion service to accept imgs in csv format in the long run? As in my case 34.000 png’s did take abit of time(around 3 hours), as the uploader started to slow down around 4.000 png files in. Could be an restriction from my side of course.
