For hobbyists that are used to working on the software end of the hacking spectrum that find themselves working to bring their machine learning-powered creations to life, there eventually comes a time when they need to pick up some tools and — gulp — build a physical device. If this is you, and your tool handling skills resemble those of Tim “The Tool Man” Taylor, and you do not declare success in any project without counting your fingers before and after the project to make sure nothing has changed, then this sort of work can be quite daunting. All joking aside, power tools can be dangerous when they are used improperly; each year 400,000 people in the US visit an emergency room due to power tool-related injuries.
This is a companion discussion topic for the original entry at https://www.edgeimpulse.com/blog/drilling-home-safe-drilling-practices-with-edge-ml
