I am uploading some audio data and the problem is that on my PC the sound is ok but after uploading it to the platform it is distorted and destroyed.
I am uploading .wav in 44100hz 32bit mono.
Any idea what I am doing wrong?
Hi @jakubsledz,
Could you provide your project ID number and one of your .wav samples so that we can replicate the issue?
Hi again. I believe this is project id: 223538.
Here is link to wav file: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Hi @jakubsledz,
When I listen to the audio file in Audacity, it sounds distorted, which matches what I am hearing in your Edge Impulse project. What program are you using to listen to the file where you say it sounds OK?
That is super wierd. I am using Quick Time. I will try to export it again.
