I selected the arduino nano BLE sense cortex M4F from the dash board
my estimates are
which does not match the output shown in the arduino uploader
any reason why this is so?
my estimates are
@marvin There’s all kinds of things included (startup code, drivers, etc.) that are loaded regardless. As an example try:
void setup() {
Serial.println("Hello from setup\n");
void loop() {
// put your main code here, to run repeatedly:
Serial.println("Hello from loop\n");
And use that as your baseline data:
Sketch uses 86672 bytes (8%) of program storage space. Maximum is 983040 bytes.
Global variables use 44696 bytes (17%) of dynamic memory, leaving 217448 bytes for local variables. Maximum is 262144 bytes.
So this is the minimum that any application will use on the Nano 33 BLE Sense. When you thus include a model first subtract those baseline numbers.
