[SER] Connecting to COM4
[SER] Retrieved configuration
[SER] Device is running AT command version 1.0.0
Configuring API key in device…[WS ] Failed to set upload settings: Traceback (most recent call last):
File “”, line 1, in
SyntaxError: can’t assign to expression
[SER] Cannot connect to remote management API using daemon, failed to read apiKey, deviceId or deviceType from device. Restarting your development board might help. Retrying in 5 seconds…[/color]
When I tried to upload images to Edge impulse with OpenMV IDE 2.6.5, I tried both API key option and login option, it gives me Error creating SSL context () error, even if I run OpenMV IDE in Administration mode. It only worked with edge-impulse-uploader after installing CLI.
