Given the following folders from a deployed EI Model is it possible to interrogate one or more files to determine if this Model is a Quantized (int8) Model or Unoptimized (float32) Model?
Quantized (int8)
|-- edge_impulse/ |--|--edge-impulse-sdk/ |--|--model-parameters/ |--|--tflite-model/
|-- edge_impulse/
|--|--tflite-model/
Hello @MMarcial,
You can check the model-parameters/model_metadata.h file, it should contain all the meta data of your impulse.
Ah indeed, thanks Louis!
Checking model-parameters/model_metadata.h for
#define EI_CLASSIFIER_TFLITE_INPUT_DATATYPE
EI_CLASSIFIER_DATATYPE_INT8
EI_CLASSIFIER_DATATYPE_FLOAT32
