Detecting wrong gesture but only in Arduino IDE pls help
I followed your provided tutorial on ‘Continuous motion recognition’. Everything worked fine and it’s recognizing the right results when i am using it in the browser. I deployed the build and put it via ‘add .ZIP libary’ in Arduino IDE and when i am running it there it is only recognizing two gestures. When i am moving it it says ‘acht’ (i am doing an eight motion) and when its sitting on my desk it correctly recognizes ‘idle’. The problem: it doesnt matter what motion i am doing it only recognizes it as ‘acht’. I have two more gestures that always appear as 0,00 - 0,03. Additionally is the anomaly factor quite high.
I used different Microcontrollers: Esp32 and Arduino Nano Esp32 but the same accelerometer: MPU-6050
I asked multiple people but we can’t find a mistake in my Arduino code and the motion recognition in the browers works fine.
This is my Arduino code:
#include <Naezz-project-1_inferencing.h>
#include <Arduino.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
Adafruit_MPU6050 mpu;
#define CONVERT_G_TO_MS2    9.80665f
#define FREQUENCY_HZ        94 /*EI_CLASSIFIER_FREQUENCY*/
#define INTERVAL_MS         (1000 / (FREQUENCY_HZ + 1))
// to classify 1 frame of data you need EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE values
float features[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
// keep track of where we are in the feature array
size_t feature_ix = 0;
void setup() {
    Serial.begin(115200);
    Serial.println("Started");
    if (!mpu.begin()) {
        Serial.println("Failed to initialize IMU!");
        while (1);
    mpu.setAccelerometerRange(MPU6050_RANGE_2_G);
    mpu.setGyroRange(MPU6050_RANGE_250_DEG);
    mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
    Serial.println("MPU6050 bereit.");
void loop() {
    //float x, y, z;
    if (millis() > last_interval_ms + INTERVAL_MS) {
        last_interval_ms = millis();
        // read sensor data in exactly the same way as in the Data Forwarder example
        //IMU.readAcceleration(x, y, z);
        sensors_event_t a, g, temp;
        mpu.getEvent(&a, &g, &temp);
        // fill the features buffer
        features[feature_ix++] = a.acceleration.x * CONVERT_G_TO_MS2;
        features[feature_ix++] = a.acceleration.y * CONVERT_G_TO_MS2;
        features[feature_ix++] = a.acceleration.z * CONVERT_G_TO_MS2;
        // features buffer full? then classify!
        if (feature_ix == EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
            ei_impulse_result_t result;
            // create signal from features frame
            signal_t signal;
            numpy::signal_from_buffer(features, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
            // run classifier
            EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false);
            if (res != 0) return;
            // print predictions
            // print the predictions
                ei_printf("%s:\t%.5f\n", result.classification[ix].label, result.classification[ix].value);
            ei_printf("anomaly:\t%.3f\n", result.anomaly);
        #endif
            // reset features frame
            feature_ix = 0;
    va_list args;
    va_start(args, format);
    va_end(args);
    if (r > 0) {
        Serial.write(print_buf);
Hi @Naezz
What frequency did you use to capture the signal in Studio, does it match what you are using in this code? Is the orientation the same when you are testing physically as was used for training? I would assume you are using a demo application here with a different sensor and could be using it in a different orientation.
My recommendation is to collect new data with your current device and sensor in a new project.
