Deployment using C++ on your desktop
How can I run the model on my desktop using C++? Why it is showing like this?
And how I can extract the coordinates and then put it into excel?
Hi @S.sarkar,
This looks to be an issue you are having with VS Code. It looks like you have not configured your project. I recommend reading the following posts:
I’m not sure what you mean by “coordinates.” If you are trying to write values to excel, the easiest method would probably be to write values to a .csv file and then import that .csv file into excel. Here is an example of writing data to a .csv file: Writing .csv files from C++ - Stack Overflow.
In addition see this Edge Impulse doc.
