I am trying to deploy my model impulse as OpenMV firmware into Nicla vision. I downloaded a .zip file containing .bin files and a ei_image_classification.py. I have loaded the corresponding .bin file into the module board successfully, but the ei_image_classification.py throws an error stating there is no file as “trained”
What name shall I put here instead of “trained”?
Hello @tejalbarnwal,
I had the same issue with the Portenta some weeks ago. I just re-uploaded the firmware and it fixed it.
Let me know if that works for you too. (also make sure to also upload the right .bin, in your case the edge_impulse_firmware_niclav.bin)
