Deploying C++ code to Himax WE-I plus
Hello! I am trying to upload my C++ code downloaded from my EdgeImpulse project by following this link:
However, the code in the main.cc uses a fixed feature array for the input. How can i change it such that i can get the input from an external accelerometer? Thank you! :slight_smile:
Hello @weijunawj,
You will need to implement that yourself as it depends on which external accelerometer each user want to use.
You need to read the accelerometer data, store that in a buffer (the array where you can statically provide the features).
Here is an example of how we do that with the arduino example so you can understand the logic:
 * Copyright (c) 2021 EdgeImpulse Inc.
 * SOFTWARE.
#include <Tutorial_Continuous_motion_recognition_inferencing.h>
#include <Arduino_LSM9DS1.h>
#define CONVERT_G_TO_MS2    9.80665f
void setup()
    Serial.begin(115200);
    if (!IMU.begin()) {
        ei_printf("Failed to initialize IMU!\r\n");
    else {
        ei_printf("IMU initialized\r\n");
        return;
* @brief      Printf function uses vsnprintf and output using Arduino Serial
* @param[in]  format     Variable argument list
   va_list args;
   va_start(args, format);
   va_end(args);
   if (r > 0) {
       Serial.write(print_buf);
* @param[in]  debug  Get debug info if true
void loop()
    ei_printf("\nStarting inferencing in 2 seconds...\n");
    delay(2000);
    ei_printf("Sampling...\n");
        IMU.readAcceleration(buffer[ix], buffer[ix + 1], buffer[ix + 2]);
        buffer[ix + 1] *= CONVERT_G_TO_MS2;
        buffer[ix + 2] *= CONVERT_G_TO_MS2;
    signal_t signal;
    if (err != 0) {
        return;
    // Run the classifier
    if (err != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Predictions ");
    ei_printf(": \n");
        ei_printf("    %s: %.5f\n", result.classification[ix].label, result.classification[ix].value);
#endif
#endif
Let me know if you have anymore questions,
omg you saved me! thank you SOOOO much Louis! :sob: :sob: :sob:
Also a note, these Arduino examples are included in the Arduino IDE when you import the .zip Arduino library deployment from the Edge Impulse Studio.
Within the Arduino IDE, select File > Examples > Your custom library > i.e. nano_ble33_sense_accelerometer_continuous
thank u so much jenny! :grin:
