Question/Issue: I am currently trying to deploy this model onto the ESP Wroom 32
I came across this example GitHub - edgeimpulse/esp32-platformio-edge-impulse-standalone-example: Minimal example code for running an Edge Impulse designed neural network on an ESP32 dev kit using platformio. It is great, however, the context of my project is live activity recognition and this is static. Can you please guide me through the deployment ?
I even tried using the following code to deploy in arduino
// Include the Arduino library here (something like your_project_inference.h)
// In the Arduino IDE see **File > Examples > Your project name - Edge Impulse > Static buffer** to get the exact name
#include <SDP-_6_Class_Dataset_inferencing.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Wire.h>
#define FREQUENCY_HZ EI_CLASSIFIER_FREQUENCY
#define INTERVAL_MS (1000 / (FREQUENCY_HZ + 1))
// to classify 1 frame of data you need EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE values
float features[EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE];
// keep track of where we are in the feature array
size_t feature_ix = 0;
Adafruit_MPU6050 mpu;
void setup() {
Serial.begin(115200);
Serial.println("Started");
if (!mpu.begin()) {
Serial.println("Failed to initialize IMU!");
while (1)
mpu.setAccelerometerRange(MPU6050_RANGE_2_G);
void loop() {
float x, y, z;
if (millis() > last_interval_ms + INTERVAL_MS) {
last_interval_ms = millis();
// read sensor data in exactly the same way as in the Data Forwarder example
sensors_event_t a, g, temp;
mpu.getEvent(&a, &g, &temp);
x = a.acceleration.x;
y = a.acceleration.y;
z = a.acceleration.z;
// fill the features buffer
features[feature_ix++] = x * CONVERT_G_TO_MS2;
features[feature_ix++] = y * CONVERT_G_TO_MS2;
features[feature_ix++] = z * CONVERT_G_TO_MS2;
// features buffer full? then classify!
if (feature_ix == EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE) {
ei_impulse_result_t result;
// create signal from features frame
signal_t signal;
numpy::signal_from_buffer(features, EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE, &signal);
// run classifier
EI_IMPULSE_ERROR res = run_classifier(&signal, &result, false);
if (res != 0) return;
// print predictions
// print the predictions
ei_printf("%s:\t%.5f\n", result.classification[ix].label, result.classification[ix].value);
ei_printf("anomaly:\t%.3f\n", result.anomaly);
#endif
// reset features frame
feature_ix = 0;
va_list args;
va_start(args, format);
va_end(args);
if (r > 0) {
Serial.write(print_buf);
it is completely confusing the activities. For instance it reports walking instead of idle. If possible can you also guide me through the process of selecting the ideal model for my data. I am suspecting that my model is flawed.
Project ID: 214635
