Deployement as Arduino Library for ESP-EYE not working
Question/Issue: Deploying project as an Arduino library for ESP-EYE issues
Project ID: 164790
**Context/Use case:
Hello everyone,
I have a technical issue that I hope someone in this community can help me with. I followed the tutorial “Recognize sound from audio” in Edge Impulse and adapted it to detect if a baby is crying or not using an ESP-EYE microcontroller. I deployed the project using the binary and it worked perfectly fine. Then, I wanted to deploy the project as an Arduino library so that I could trigger some actions based on the baby crying detection.
I followed the tutorial on how to deploy the project as an Arduino library for the ESP-EYE, which involved installing the board, choosing the right settings, and enabling PSRAM. However, when I run the “microphone” or “microphone_continuous” sketch on the microcontroller, the probabilities for each label don’t change. In the “microphone_continuous” sketch, when I set “debug” to true, I get the error message “Error sample buffer overrun. Decrease the number of slices per model window (EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)”. I tried different values for EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW, including 1, but it didn’t change anything. The non-continuous sketch doesn’t work either.
I’m a bit lost and would appreciate any help in finding a solution to this issue. Thank you so much in advance for your assistance!
See this for info on the sample buffer overrun.
There is a nice visual here that should help you adjust the design of your Impulse.
Thank you for your prompt reply! I have been experimenting with various settings to adjust the impulse, but I have encountered some difficulties when trying to implement it as an Arduino library. Interestingly, the impulse works flawlessly with the ready-to-go binary, which has led me to some confusion. I am currently focused on getting the “esp32_microphone” example sketch to work before proceeding with the continuous sketch. However, I am feeling a bit lost at the moment and could use some guidance. In order to test each setting, I download the zip arduino library and import it in the Arduino IDE (version 2.0.4), then I use the following for the board setting :
And this is what I get every time :
It compiles and run but the probability for each label never changes.
I am wondering if you could help me identify where the problem could be coming from? Additionally, I am curious why it works perfectly as a binary but not as an Arduino library?
Thank you in advance for your assistance
Post your INO file. It might be your are actually running a static buffer INO that would give the results shown.
Here is the code from the INO file :
/* Edge Impulse Arduino examples
 * Copyright (c) 2022 EdgeImpulse Inc.
 * Permission is hereby granted, free of charge, to any person obtaining a copy
 * of this software and associated documentation files (the "Software"), to deal
 * in the Software without restriction, including without limitation the rights
 * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
 * copies of the Software, and to permit persons to whom the Software is
 * furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
 * SOFTWARE.
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK   0
 ** NOTE: If you run into TFLite arena allocation issue.
 ** This may be due to may dynamic memory fragmentation.
 ** Try defining "-DEI_CLASSIFIER_ALLOCATION_STATIC" in boards.local.txt (create
 ** if it doesn't exist) and copy this file to
 ** `<ARDUINO_CORE_INSTALL_PATH>/arduino/hardware/<mbed_core>/<core_version>/`.
 ** See
 ** (https://support.arduino.cc/hc/en-us/articles/360012076960-Where-are-the-installed-cores-located-)
 ** to find where Arduino installs cores on your machine.
 ** If the problem persists then there's not enough memory for this model and application.
/* Includes ---------------------------------------------------------------- */
#include <baby_cry_detection_inferencing.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/i2s.h"
/** Audio buffers, pointers and selectors */
typedef struct {
    int16_t *buffer;
    uint8_t buf_ready;
    uint32_t buf_count;
    uint32_t n_samples;
} inference_t;
static inference_t inference;
static const uint32_t sample_buffer_size = 2048;
static signed short sampleBuffer[sample_buffer_size];
static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
static bool record_status = true;
 * @brief      Arduino setup function
void setup()
    // put your setup code here, to run once:
    Serial.begin(115200);
    // comment out the below line to cancel the wait for USB connection (needed for native USB)
    while (!Serial);
    Serial.println("Edge Impulse Inferencing Demo");
    // summary of inferencing settings (from model_metadata.h)
    ei_printf("Inferencing settings:\n");
    ei_printf("\tInterval: ");
    ei_printf_float((float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf(" ms.\n");
    ei_printf("\tFrame size: %d\n", EI_CLASSIFIER_DSP_INPUT_FRAME_SIZE);
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    ei_printf("\tNo. of classes: %d\n", sizeof(ei_classifier_inferencing_categories) / sizeof(ei_classifier_inferencing_categories[0]));
    ei_printf("\nStarting continious inference in 2 seconds...\n");
    ei_sleep(2000);
    if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
        ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
        return;
    ei_printf("Recording...\n");
 * @brief      Arduino main function. Runs the inferencing loop.
void loop()
    bool m = microphone_inference_record();
    if (!m) {
        ei_printf("ERR: Failed to record audio...\n");
        return;
    signal_t signal;
    signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;
    signal.get_data = &microphone_audio_signal_get_data;
    ei_impulse_result_t result = { 0 };
    EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", r);
        return;
    // print the predictions
    ei_printf("Predictions ");
    ei_printf("(DSP: %d ms., Classification: %d ms., Anomaly: %d ms.)",
        result.timing.dsp, result.timing.classification, result.timing.anomaly);
    ei_printf(": \n");
    for (size_t ix = 0; ix < EI_CLASSIFIER_LABEL_COUNT; ix++) {
        ei_printf("    %s: ", result.classification[ix].label);
        ei_printf_float(result.classification[ix].value);
        ei_printf("\n");
#if EI_CLASSIFIER_HAS_ANOMALY == 1
    ei_printf("    anomaly score: ");
    ei_printf_float(result.anomaly);
    ei_printf("\n");
#endif
static void audio_inference_callback(uint32_t n_bytes)
    for(int i = 0; i < n_bytes>>1; i++) {
        inference.buffer[inference.buf_count++] = sampleBuffer[i];
        if(inference.buf_count >= inference.n_samples) {
          inference.buf_count = 0;
          inference.buf_ready = 1;
static void capture_samples(void* arg) {
  const int32_t i2s_bytes_to_read = (uint32_t)arg;
  size_t bytes_read = i2s_bytes_to_read;
  while (record_status) {
    /* read data at once from i2s */
    i2s_read((i2s_port_t)1, (void*)sampleBuffer, i2s_bytes_to_read, &bytes_read, 100);
    if (bytes_read <= 0) {
      ei_printf("Error in I2S read : %d", bytes_read);
    else {
        if (bytes_read < i2s_bytes_to_read) {
        ei_printf("Partial I2S read");
        // scale the data (otherwise the sound is too quiet)
        for (int x = 0; x < i2s_bytes_to_read/2; x++) {
            sampleBuffer[x] = (int16_t)(sampleBuffer[x]) * 8;
        if (record_status) {
            audio_inference_callback(i2s_bytes_to_read);
        else {
            break;
  vTaskDelete(NULL);
 * @brief      Init inferencing struct and setup/start PDM
 * @param[in]  n_samples  The n samples
 * @return     { description_of_the_return_value }
static bool microphone_inference_start(uint32_t n_samples)
    inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
    if(inference.buffer == NULL) {
        return false;
    inference.n_samples  = n_samples;
    inference.buf_ready  = 0;
    if (i2s_init(EI_CLASSIFIER_FREQUENCY)) {
        ei_printf("Failed to start I2S!");
    ei_sleep(100);
    xTaskCreate(capture_samples, "CaptureSamples", 1024 * 32, (void*)sample_buffer_size, 10, NULL);
    return true;
 * @brief      Wait on new data
 * @return     True when finished
static bool microphone_inference_record(void)
    bool ret = true;
    while (inference.buf_ready == 0) {
        delay(10);
    return ret;
 * Get raw audio signal data
static int microphone_audio_signal_get_data(size_t offset, size_t length, float *out_ptr)
    numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
    return 0;
 * @brief      Stop PDM and release buffers
static void microphone_inference_end(void)
    i2s_deinit();
    ei_free(inference.buffer);
static int i2s_init(uint32_t sampling_rate) {
  // Start listening for audio: MONO @ 8/16KHz
  i2s_config_t i2s_config = {
      .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_TX),
      .sample_rate = sampling_rate,
      .bits_per_sample = (i2s_bits_per_sample_t)16,
      .channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
      .communication_format = I2S_COMM_FORMAT_I2S,
      .intr_alloc_flags = 0,
      .dma_buf_count = 8,
      .dma_buf_len = 512,
      .use_apll = false,
      .tx_desc_auto_clear = false,
      .fixed_mclk = -1,
  i2s_pin_config_t pin_config = {
      .bck_io_num = 26,    // IIS_SCLK
      .ws_io_num = 32,     // IIS_LCLK
      .data_out_num = -1,  // IIS_DSIN
      .data_in_num = 33,   // IIS_DOUT
  esp_err_t ret = 0;
  ret = i2s_driver_install((i2s_port_t)1, &i2s_config, 0, NULL);
  if (ret != ESP_OK) {
    ei_printf("Error in i2s_driver_install");
  ret = i2s_set_pin((i2s_port_t)1, &pin_config);
    ei_printf("Error in i2s_set_pin");
  ret = i2s_zero_dma_buffer((i2s_port_t)1);
    ei_printf("Error in initializing dma buffer with 0");
  return int(ret);
static int i2s_deinit(void) {
    i2s_driver_uninstall((i2s_port_t)1); //stop & destroy i2s driver
    return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
This is the “esp32_microphone” example sketch. I tried the “static buffer” example sketch and it worked for the sample that I gave it. But the “esp32_microphone” gives the result shown in the previous post.
@beneficial01
  • I verified you are using the example INO, esp32_microphone.ino, from Edge Impulse in an un-modified form, only adding in your custom EI library.
  • I duplicated the issue with my Edge Impulse Keyword Model on an ESP-EYE.
@louis this is a bug wherein the inference always gives the same Prediction Scores. The DSP period varies a little as expected.
OK I found what the issue was. I first started by checking if the recording of the microphone was ok and I realize that the sampling buffer was always empty. This is because apparently the ESP-EYE only works with a bit width of 32 bits while it is initialized in the example sketch with a bit width of 16 bits (huge shout-out at GitHub - squix78/esp32-mic-fft: Sample code for using the microphone via I2S on a ESP-EYE board). I then adapted the whole code according to this new configuration and now it works !!
Here is the working code :
 * SOFTWARE.
 ** See
const i2s_port_t I2S_PORT = I2S_NUM_0;
typedef struct {
    int32_t *buffer;
    uint8_t buf_ready;
    uint32_t buf_count;
    uint32_t n_samples;
} inference_t;
static const uint32_t sample_buffer_size = 512;
static int32_t sampleBuffer[sample_buffer_size];
static bool debug_nn = true; // Set this to true to see e.g. features generated from the raw signal
void setup()
    while (!Serial);
    ei_sleep(2000);
        return;
void loop()
    // Test to check if audio is recorded : PASSED
    /*Serial.println();
    for (int i = 0; i < sample_buffer_size; i++) Serial.print(sampleBuffer[i]);
    Serial.println();*/
    // Test to check if audio makes it to the inference buffer : PASSED
    /*Serial.println();
    for (int i = 0; i < sample_buffer_size; i++) Serial.print(inference.buffer[i]);
    Serial.println();*/
    if (!m) {
        return;
    signal_t signal;
        return;
    ei_printf(": \n");
        ei_printf("\n");
    ei_printf("\n");
#endif
    i2s_read(I2S_PORT, (void*)sampleBuffer, i2s_bytes_to_read, &bytes_read, portMAX_DELAY); //TIMOUT WAS 100
    else {
            sampleBuffer[x] = (int32_t)(sampleBuffer[x]) * 8;
        else {
            break;
  vTaskDelete(NULL);
static bool microphone_inference_start(int32_t n_samples)
    inference.buffer = (int32_t *)malloc(n_samples * sizeof(int32_t));
        return false;
    ei_sleep(100);
    return true;
    bool ret = true;
        delay(10);
    return ret;
    numpy::int32_to_float(&inference.buffer[offset], out_ptr, length);
    /*Serial.println();
    for (int i = 0; i < length; i++) Serial.print(out_ptr[i]);
    Serial.println();*/
    /*Serial.println();
    for (int i = 0; i < length; i++) Serial.print(inference.buffer[i]);
    Serial.println();*/
    //for (int i = 0; i < length; i++) {
      //out_ptr[i] = (float)inference.buffer[i];
    //memcpy(out_ptr, inference.buffer + offset, length * sizeof(float));
    return 0;
    i2s_deinit();
      .bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
      .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
      .dma_buf_count = 8,
      .dma_buf_len = 512,
      .use_apll = false,
      .fixed_mclk = -1,
  esp_err_t ret = 0;
  ret = i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
  ret = i2s_set_pin(I2S_PORT, &pin_config);
  ret = i2s_zero_dma_buffer(I2S_PORT);
  return int(ret);
    i2s_driver_uninstall(I2S_PORT); //stop & destroy i2s driver
    return 0;
#endif
Hello @beneficial01,
Thanks for sharing with the community, I’m sure it will be useful to some other users!
@beneficial01 Good job at finding a solution.
I do not understand why changing the Inference Buffer[] and the Samples Buffer[] from 16-bit to 32-bit makes this code work on an ESP-EYE but indeed it works.
Interesting to me. I think this is solving the problem in the wrong way. The arduino library export has the below setup code. I wanted to test my mic and found some really cool waveform plotter here: https://dronebotworkshop.com/esp32-i2s/. This works just fine and gives a neat real-time plot.
After changing the default from RIGHT to LEFT, seems to work as expected.
      //.channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT, //arduino .zip library default
      .channel_format = I2S_CHANNEL_FMT_ONLY_LEFT, //change to this and it works!
      .dma_buf_count = 8,
      .dma_buf_len = 64,
      .use_apll = false,
      .fixed_mclk = -1,
Now the million $ question is… why does the 32bit sample work also? Are there 16 zero bits for the other channel that are getting discarded? Would be fun to know.
Also, this might be a persistent bug in the edge impulse core deployment. No idea how to raise a ticket for that. Note that this erroneous behavior doesn’t exist in the prepackaged firmware for the ESP-EYE – only the arduino.
Have you seen the very in-depth work alkorisedge is currently doing?
