Deployement as Arduino Library for ESP-EYE not working
Question/Issue: Deploying project as an Arduino library for ESP-EYE issues
Project ID: 164790
**Context/Use case:
Hello everyone,
I have a technical issue that I hope someone in this community can help me with. I followed the tutorial “Recognize sound from audio” in Edge Impulse and adapted it to detect if a baby is crying or not using an ESP-EYE microcontroller. I deployed the project using the binary and it worked perfectly fine. Then, I wanted to deploy the project as an Arduino library so that I could trigger some actions based on the baby crying detection.
I followed the tutorial on how to deploy the project as an Arduino library for the ESP-EYE, which involved installing the board, choosing the right settings, and enabling PSRAM. However, when I run the “microphone” or “microphone_continuous” sketch on the microcontroller, the probabilities for each label don’t change. In the “microphone_continuous” sketch, when I set “debug” to true, I get the error message “Error sample buffer overrun. Decrease the number of slices per model window (EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW)”. I tried different values for EI_CLASSIFIER_SLICES_PER_MODEL_WINDOW, including 1, but it didn’t change anything. The non-continuous sketch doesn’t work either.
I’m a bit lost and would appreciate any help in finding a solution to this issue. Thank you so much in advance for your assistance!
See this for info on the sample buffer overrun.
There is a nice visual here that should help you adjust the design of your Impulse.
Thank you for your prompt reply! I have been experimenting with various settings to adjust the impulse, but I have encountered some difficulties when trying to implement it as an Arduino library. Interestingly, the impulse works flawlessly with the ready-to-go binary, which has led me to some confusion. I am currently focused on getting the “esp32_microphone” example sketch to work before proceeding with the continuous sketch. However, I am feeling a bit lost at the moment and could use some guidance. In order to test each setting, I download the zip arduino library and import it in the Arduino IDE (version 2.0.4), then I use the following for the board setting :
And this is what I get every time :
It compiles and run but the probability for each label never changes.
I am wondering if you could help me identify where the problem could be coming from? Additionally, I am curious why it works perfectly as a binary but not as an Arduino library?
Thank you in advance for your assistance
Post your INO file. It might be your are actually running a static buffer INO that would give the results shown.
Here is the code from the INO file :
 * SOFTWARE.
// If your target is limited in memory remove this macro to save 10K RAM
#define EIDSP_QUANTIZE_FILTERBANK   0
 ** NOTE: If you run into TFLite arena allocation issue.
 ** This may be due to may dynamic memory fragmentation.
 ** Try defining "-DEI_CLASSIFIER_ALLOCATION_STATIC" in boards.local.txt (create
 ** if it doesn't exist) and copy this file to
 ** `<ARDUINO_CORE_INSTALL_PATH>/arduino/hardware/<mbed_core>/<core_version>/`.
 ** See
 ** (https://support.arduino.cc/hc/en-us/articles/360012076960-Where-are-the-installed-cores-located-)
 ** to find where Arduino installs cores on your machine.
 ** If the problem persists then there's not enough memory for this model and application.
#include <baby_cry_detection_inferencing.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/i2s.h"
/** Audio buffers, pointers and selectors */
typedef struct {
    int16_t *buffer;
    uint8_t buf_ready;
    uint32_t buf_count;
    uint32_t n_samples;
} inference_t;
static inference_t inference;
static const uint32_t sample_buffer_size = 2048;
static signed short sampleBuffer[sample_buffer_size];
static bool record_status = true;
void setup()
    Serial.begin(115200);
    while (!Serial);
    ei_printf("\tInterval: ");
    ei_printf_float((float)EI_CLASSIFIER_INTERVAL_MS);
    ei_printf(" ms.\n");
    ei_printf("\tSample length: %d ms.\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT / 16);
    ei_sleep(2000);
    if (microphone_inference_start(EI_CLASSIFIER_RAW_SAMPLE_COUNT) == false) {
        ei_printf("ERR: Could not allocate audio buffer (size %d), this could be due to the window length of your model\r\n", EI_CLASSIFIER_RAW_SAMPLE_COUNT);
        return;
    ei_printf("Recording...\n");
 * @brief      Arduino main function. Runs the inferencing loop.
void loop()
    if (!m) {
        return;
    signal_t signal;
    signal.total_length = EI_CLASSIFIER_RAW_SAMPLE_COUNT;
    signal.get_data = &microphone_audio_signal_get_data;
    EI_IMPULSE_ERROR r = run_classifier(&signal, &result, debug_nn);
    if (r != EI_IMPULSE_OK) {
        return;
    // print the predictions
    ei_printf("Predictions ");
    ei_printf(": \n");
        ei_printf("    %s: ", result.classification[ix].label);
        ei_printf_float(result.classification[ix].value);
        ei_printf("\n");
    ei_printf("    anomaly score: ");
    ei_printf_float(result.anomaly);
    ei_printf("\n");
#endif
static void audio_inference_callback(uint32_t n_bytes)
    for(int i = 0; i < n_bytes>>1; i++) {
        inference.buffer[inference.buf_count++] = sampleBuffer[i];
        if(inference.buf_count >= inference.n_samples) {
          inference.buf_count = 0;
          inference.buf_ready = 1;
static void capture_samples(void* arg) {
  const int32_t i2s_bytes_to_read = (uint32_t)arg;
  size_t bytes_read = i2s_bytes_to_read;
  while (record_status) {
    /* read data at once from i2s */
    i2s_read((i2s_port_t)1, (void*)sampleBuffer, i2s_bytes_to_read, &bytes_read, 100);
    if (bytes_read <= 0) {
      ei_printf("Error in I2S read : %d", bytes_read);
    else {
        if (bytes_read < i2s_bytes_to_read) {
        ei_printf("Partial I2S read");
        // scale the data (otherwise the sound is too quiet)
        for (int x = 0; x < i2s_bytes_to_read/2; x++) {
            sampleBuffer[x] = (int16_t)(sampleBuffer[x]) * 8;
        if (record_status) {
            audio_inference_callback(i2s_bytes_to_read);
        else {
            break;
  vTaskDelete(NULL);
 * @brief      Init inferencing struct and setup/start PDM
 * @param[in]  n_samples  The n samples
 * @return     { description_of_the_return_value }
    inference.buffer = (int16_t *)malloc(n_samples * sizeof(int16_t));
    if(inference.buffer == NULL) {
        return false;
    inference.n_samples  = n_samples;
    inference.buf_ready  = 0;
    if (i2s_init(EI_CLASSIFIER_FREQUENCY)) {
        ei_printf("Failed to start I2S!");
    ei_sleep(100);
    xTaskCreate(capture_samples, "CaptureSamples", 1024 * 32, (void*)sample_buffer_size, 10, NULL);
    return true;
 * @brief      Wait on new data
 * @return     True when finished
    bool ret = true;
    while (inference.buf_ready == 0) {
        delay(10);
    return ret;
 * Get raw audio signal data
    numpy::int16_to_float(&inference.buffer[offset], out_ptr, length);
    return 0;
 * @brief      Stop PDM and release buffers
static void microphone_inference_end(void)
    i2s_deinit();
    ei_free(inference.buffer);
static int i2s_init(uint32_t sampling_rate) {
  // Start listening for audio: MONO @ 8/16KHz
  i2s_config_t i2s_config = {
      .mode = (i2s_mode_t)(I2S_MODE_MASTER | I2S_MODE_RX | I2S_MODE_TX),
      .sample_rate = sampling_rate,
      .bits_per_sample = (i2s_bits_per_sample_t)16,
      .channel_format = I2S_CHANNEL_FMT_ONLY_RIGHT,
      .communication_format = I2S_COMM_FORMAT_I2S,
      .intr_alloc_flags = 0,
      .dma_buf_count = 8,
      .dma_buf_len = 512,
      .use_apll = false,
      .tx_desc_auto_clear = false,
      .fixed_mclk = -1,
  i2s_pin_config_t pin_config = {
      .bck_io_num = 26,    // IIS_SCLK
      .ws_io_num = 32,     // IIS_LCLK
      .data_out_num = -1,  // IIS_DSIN
      .data_in_num = 33,   // IIS_DOUT
  esp_err_t ret = 0;
  ret = i2s_driver_install((i2s_port_t)1, &i2s_config, 0, NULL);
  if (ret != ESP_OK) {
    ei_printf("Error in i2s_driver_install");
  ret = i2s_set_pin((i2s_port_t)1, &pin_config);
    ei_printf("Error in i2s_set_pin");
  ret = i2s_zero_dma_buffer((i2s_port_t)1);
    ei_printf("Error in initializing dma buffer with 0");
  return int(ret);
static int i2s_deinit(void) {
    i2s_driver_uninstall((i2s_port_t)1); //stop & destroy i2s driver
    return 0;
#if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_MICROPHONE
#error "Invalid model for current sensor."
#endif
This is the “esp32_microphone” example sketch. I tried the “static buffer” example sketch and it worked for the sample that I gave it. But the “esp32_microphone” gives the result shown in the previous post.
@beneficial01
  • I verified you are using the example INO, esp32_microphone.ino, from Edge Impulse in an un-modified form, only adding in your custom EI library.
  • I duplicated the issue with my Edge Impulse Keyword Model on an ESP-EYE.
@louis this is a bug wherein the inference always gives the same Prediction Scores. The DSP period varies a little as expected.
OK I found what the issue was. I first started by checking if the recording of the microphone was ok and I realize that the sampling buffer was always empty. This is because apparently the ESP-EYE only works with a bit width of 32 bits while it is initialized in the example sketch with a bit width of 16 bits (huge shout-out at GitHub - squix78/esp32-mic-fft: Sample code for using the microphone via I2S on a ESP-EYE board). I then adapted the whole code according to this new configuration and now it works !!
Here is the working code :
 * SOFTWARE.
 ** See
const i2s_port_t I2S_PORT = I2S_NUM_0;
typedef struct {
    int32_t *buffer;
    uint8_t buf_ready;
    uint32_t buf_count;
    uint32_t n_samples;
} inference_t;
static const uint32_t sample_buffer_size = 512;
static int32_t sampleBuffer[sample_buffer_size];
static bool debug_nn = true; // Set this to true to see e.g. features generated from the raw signal
void setup()
    while (!Serial);
    ei_sleep(2000);
        return;
void loop()
    // Test to check if audio is recorded : PASSED
    /*Serial.println();
    for (int i = 0; i < sample_buffer_size; i++) Serial.print(sampleBuffer[i]);
    Serial.println();*/
    // Test to check if audio makes it to the inference buffer : PASSED
    /*Serial.println();
    for (int i = 0; i < sample_buffer_size; i++) Serial.print(inference.buffer[i]);
    Serial.println();*/
    if (!m) {
        return;
    signal_t signal;
        return;
    ei_printf(": \n");
        ei_printf("\n");
    ei_printf("\n");
#endif
    i2s_read(I2S_PORT, (void*)sampleBuffer, i2s_bytes_to_read, &bytes_read, portMAX_DELAY); //TIMOUT WAS 100
    else {
            sampleBuffer[x] = (int32_t)(sampleBuffer[x]) * 8;
        else {
            break;
  vTaskDelete(NULL);
static bool microphone_inference_start(int32_t n_samples)
    inference.buffer = (int32_t *)malloc(n_samples * sizeof(int32_t));
        return false;
    ei_sleep(100);
    return true;
    bool ret = true;
        delay(10);
    return ret;
    numpy::int32_to_float(&inference.buffer[offset], out_ptr, length);
    /*Serial.println();
    for (int i = 0; i < length; i++) Serial.print(out_ptr[i]);
    Serial.println();*/
    /*Serial.println();
    for (int i = 0; i < length; i++) Serial.print(inference.buffer[i]);
    Serial.println();*/
    //for (int i = 0; i < length; i++) {
      //out_ptr[i] = (float)inference.buffer[i];
    //memcpy(out_ptr, inference.buffer + offset, length * sizeof(float));
    return 0;
    i2s_deinit();
      .bits_per_sample = I2S_BITS_PER_SAMPLE_32BIT,
      .intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
      .dma_buf_count = 8,
      .dma_buf_len = 512,
      .use_apll = false,
      .fixed_mclk = -1,
  esp_err_t ret = 0;
  ret = i2s_driver_install(I2S_PORT, &i2s_config, 0, NULL);
  ret = i2s_set_pin(I2S_PORT, &pin_config);
  ret = i2s_zero_dma_buffer(I2S_PORT);
  return int(ret);
    i2s_driver_uninstall(I2S_PORT); //stop & destroy i2s driver
    return 0;
#endif
Hello @beneficial01,
Thanks for sharing with the community, I’m sure it will be useful to some other users!
@beneficial01 Good job at finding a solution.
I do not understand why changing the Inference Buffer[] and the Samples Buffer[] from 16-bit to 32-bit makes this code work on an ESP-EYE but indeed it works.
