Hello, makefiles have always been the bane of my existence. I just can’t seem to figure them out. I recently deployed my object detection model to the C++ library to run on a Kria KV260.
I’m trying to compile my code using the Makefile in the tutorial, but get the following error:
g++: fatal error: cannot specify ‘-o’ with ‘-c’, ‘-S’ or ‘-E’ with multiple files
I searched the interwebz but couldn’t find anything useful on how to resolve. I don’t think I have references to duplicate files. Each time I run make -j 4 it seems to error out on a different file.
Any Makefile gurus out there? Any idea what could be causing it? Thanks!
That worked, thank you! It takes about 19s for inference, but it is working at least! Thank you for the insight.
I did see the other tutorial. There are a couple gaps in it that I’ve mentioned in a separate thread, and I don’t think there is an equivalent model in the Xilinx Model Zoo for the MobileNet V2 SSD model that Edge Impulse uses for object detection.
